diyAudio
diyAudio (http://www.diyaudio.com/forums/index.php)
-   Tubes / Valves (http://www.diyaudio.com/forums/tubes-valves/)
-   -   6N16B preamp (http://www.diyaudio.com/forums/tubes-valves/219331-6n16b-preamp.html)
merlin el mago 8th September 2012 12:59 PM
6N16B preamp
1 Attachment(s)
I want to make a linestage with 6N16B, I have found this schematic, could help me to see if have any issue or a way to upgrade it. More information in this link http://freestompboxes.org/viewtopic.php?f=2&t=9923, but I can see clearly the B+ & filament heater requirements.
Zen Mod 8th September 2012 01:03 PM
that's guitar thing
besides that - I'm lazy to search for 6Н16Б datasheet
merlin el mago 8th September 2012 01:05 PM
6N16B | Tubes Information I want make it for HIFI.
Zen Mod 8th September 2012 01:13 PM
you need graphs
merlin el mago 8th September 2012 01:28 PM
1 Attachment(s)
Here the datasheet with graphs
Zen Mod 8th September 2012 01:52 PM
fancy to play with DN2540 CCS in anode ?
merlin el mago 8th September 2012 02:44 PM
I use Salas HV shunt regulator, suggestions to improve the schematic giving information B+ heaters voltage etc will welcome.
Zen Mod 8th September 2012 03:34 PM
1 Attachment(s)
try like this
Rout in range of 4K4
presumed load around 100K
use Ub in range of 120-130V
expect around 95V at anode
pre-set CCS to 5mA (I'm lazy to read datasheet toi determine exact resistor )
float heater supply and lift it to 30-40V
best to heat with LM317 based CCS , preset to 400mA , when tube is hot , set exactly to 6V3
artosalo 8th September 2012 04:10 PM
Originally Posted by merlin el mago (http://www.diyaudio.com/forums/tubes-valves/219331-6n16b-preamp-post3156897.html#post3156897)
I want to make a linestage with 6N16B...
What are your requirements ?
- gain
- output impedance; low (cathode follower output) or higher (anode output)
- inverting or non-inverting construction
- low distortion or "tube sound" design
artosalo 8th September 2012 05:09 PM
Here is one with high performance, i.e. low distortion, flat frequency response and low output impedance. Technical specification is in the schematic.
http://kuva.termiitti.com/image/26819.gif
Kuva 26819 - Kuva.termiitti.com
Resources saved on this page: MySQL 18.75%
