#21 |
Irrelevant questions: the amp is inverting. You need non-inverting. That means, you need to go with 2 stages and feedback around them defining voltage gain.
If I disappear suddenly, that means I finally created a time machine and pushed wrong button that brought me to Stalin's Russia. In any experiment any result is the result. Even if it is negative. |
#22 | |
#23 |
all your questions are redundant
regulator is not having any connection with "if I don't use DN2540" in this case , Iq of stage is set with DN2540 at 5mA , so Salas reg must nbe set at at least 10mA , twice that even better anyway - if you're going to use proper shunt reg - taking in account that reg itself demands some space , then use proper tube ....... with lower Ri , greater xconductance I don't like sissy tubes 6Н23П (ECC88=6DJ8) is weakest tube I'll use in line stage
my Papa is smarter than your Nelson ! tnx to clean thread ; Cook Book ; PSM LS Cook Book ; Baby Diyaudio FORUM ; Mighty ZM's Bloggg;I'm dumb
#24 |
Zen could you share the schematic you use in your line stage?
#25 |
regarding #22
so - 3 stages - two gain stages , cascaded , with cathode follower look for any of Allen Wright's SE line stage constructions edit : didn't saw x60 ...... in that case AW constructions aren't helpful ......
#26 | |
none in this moment - AVC even without buffers planning to try soon some balanced bstrd with xformer output if works as planned , will post
#27 |
#28 |
If design & sound is good can low the gain to x30 or x40
#29 |
Here is something that fulfils your specification. Performance is mentioned in the schematic again.
(You can omit R14) Would this be OK ? ![]() Kuva 26832 - Kuva.termiitti.com |
#30 |
Yes
![]() Needs a special heater wiring, wich heaters requirements, volts & ampers? Last edited by merlin el mago; 8th September 2012 at 08:15 PM. |
| Running a tube preamp into a solid state preamp? | Pckid212 | Solid State | 5 | 6th January 2013 10:12 PM |
| 6111/6n16b - linestage noise problem | lordearl | Tubes / Valves | 26 | 15th April 2012 11:04 PM |
| DOUBLE TRIODE (6N16B) | Drakula38 | Tubes / Valves | 6 | 31st December 2011 04:41 PM |
| Tube Preamp Popping on Source Input Change (?) / 6DJ8 Preamp On Chip Amps | MartyM | Tubes / Valves | 3 | 16th October 2008 04:52 AM |
| Guitar Preamp = MIC Preamp = other preamp ,,are they all same? | Paswa | Solid State | 1 | 12th March 2008 05:16 PM |
