Old 8th September 2012, 05:15 PM   #11
Wavebourn's Avatar
Send a message via Skype™ to Wavebourn
There were many preamps discussed using 6SN7 and 6N1P. You may borrow ideas from them.
If I disappear suddenly, that means I finally created a time machine and pushed wrong button that brought me to Stalin's Russia. In any experiment any result is the result. Even if it is negative.
Old 8th September 2012, 05:20 PM   #12
artosalo's Avatar
All DIYers can not modify circuits using 6SN7, 6N1P, etc. to 6N16B.
Therefore I wanted to give an example.
Old 8th September 2012, 05:27 PM   #13
Wavebourn's Avatar
And you gave a good example. Add there Zen Mod's proposal, and it will be even better.
Old 8th September 2012, 05:34 PM   #14
artosalo's Avatar
Two FETs at the first anode as CCS ?
Old 8th September 2012, 05:39 PM   #15
Wavebourn's Avatar
Yes, something like that. But I personally prefer a single FET with resistive degradation, connected like gyrator. However, any active load may contribute more noise than single resistor, but resulting distortions will be lower.
Old 8th September 2012, 05:53 PM   #16
artosalo's Avatar
Then the whole design must be changed since the size of anode resistor (together with resistors at the cathode) determines the gain, and I wanted to set it to some 10 dB. Line stage usually needs small gain.
In general I think that two FETs at the anode of medium or low mu triode is waisting of resources. Just one is sufficient. It usually represents some 500k to over 1M resistance. There is not much difference if this impedance is multiplied by 10 (even though some guys can clearly hear the difference).
Old 8th September 2012, 06:21 PM   #17
Wavebourn's Avatar
Sure, some guys can hear the difference when higher capacitance of more complex active load adds roll-off on highs.
Old 8th September 2012, 06:52 PM   #18
merlin el mago's Avatar
What are your requirements ?
- gain
- output impedance; low (cathode follower output) or higher (anode output)
- inverting or non-inverting construction
- low distortion or "tube sound" design
requirements:
-high gain
-low output impedance
-high input impedance
-non-inverting
-low distortion
-flat frecuency response
Old 8th September 2012, 06:57 PM   #19
Wavebourn's Avatar
The only concrete requirement is "Non-inverting", the rest is undefined. You have to put numbers for each criterion.
-high gain -- how much?
-low output impedance --lower than...?
-high input impedance --higher than...?
-non-inverting
-low distortion --what kind of distortions..., which level...?
-flat frecuency response --how many DB in which band?
Old 8th September 2012, 06:59 PM   #20
Originally Posted by Zen Mod View Post
try like this
Rout in range of 4K4
presumed load around 100K
use Ub in range of 120-130V
expect around 95V at anode
pre-set CCS to 5mA (I'm lazy to read datasheet toi determine exact resistor )
float heater supply and lift it to 30-40V
best to heat with LM317 based CCS , preset to 400mA , when tube is hot , set exactly to 6V3
thanks for schematic:
input/output impedance?
gain?
if I don't use DN2450, how much current & voltage have to set my regulator?
Running a tube preamp into a solid state preamp? Pckid212 Solid State 5 6th January 2013 10:12 PM
6111/6n16b - linestage noise problem lordearl Tubes / Valves 26 15th April 2012 11:04 PM
DOUBLE TRIODE (6N16B) Drakula38 Tubes / Valves 6 31st December 2011 04:41 PM
Tube Preamp Popping on Source Input Change (?) / 6DJ8 Preamp On Chip Amps MartyM Tubes / Valves 3 16th October 2008 04:52 AM
Guitar Preamp = MIC Preamp = other preamp ,,are they all same? Paswa Solid State 1 12th March 2008 05:16 PM
Copyright ©1999-2013 diyAudio
