Hi guys, looking to make a wood enclosure/cover to go over my KT88 amp - top would be slatted with wire mesh to let the heat dissipate. Wondering how much room above the tubes I will safe with - 2"? Thanks for any thoughts.
#2 |
expert in tautology
Many commercial tube amps used perf metal that is 1-2" above the tubes. The metal can still get hot and/or cause the paint to discolor over time.
It's really a question of how much temp rise you can stand on the metal... _-_-bear
_-_-bear http://www.bearlabs.com [...2SJ74 Toshiba bogus asian parts - beware! ] -- Btw, I don't actually know anything, FYI --
#3 |
Thanks Bear
#4 |
Location: Mar del Plata, a BIG seasonal getaway city, can see the Ocean from our residence.
Distance from tube to tube in the horizontal plane is defined as One and a half 'envelope widths'(1 1/2). If the tubes are of different sizes, take the smallest example times 1.5 .
__________________________________________________ _Rick............. |
| What gauge enclosure for KT88 AMP? | jhl1963 | Tubes / Valves | 11 | 8th September 2012 11:07 PM |
| JJ KT88 tubes glowing bright yellow. | bottletop | Tubes / Valves | 41 | 14th January 2011 10:21 PM |
| Substituting GU50 tubes for KT88 | ben_f_m | Tubes / Valves | 5 | 16th March 2009 09:45 PM |
| KT88 tubes | arvin | Tubes / Valves | 8 | 6th March 2007 08:40 AM |
| A typical KT88 tubes | oasis_oasis | Tubes / Valves | 0 | 18th January 2007 02:31 PM |
