What gauge enclosure for KT88 AMP?
Old 6th September 2012, 02:01 PM   #1
jhl1963 is offline jhl1963
Default What gauge enclosure for KT88 AMP?
Guys, Im looking at several enclosure options and am between a hammond (18 gauge) and a cake pan (14 gauge). Wondering if anyone has any experience with the hammond or can tell me if the 18 gauge is strong enough for some serious transformers?
Thanks!
Fat Daddio's Anodized Aluminum Cake Pan 12"x16"x3" Deep | eBay
Hammond Mfg. - Aluminum Chassis & Bottom Plates (1444 & 1434 Series)
Old 6th September 2012, 03:01 PM   #2
palmas is offline palmas  Portugal
Nop, it will flex if you add serious iron on it!
need some sort of structure to keep it in the original shape.
For those big iron beasts I use 5mm duraluminium...
Old 6th September 2012, 05:49 PM   #3
kevinkr's Avatar
For about the cost of a flimsy Hammond chassis you can have Dirty Dawg Amps make you a brawny custom aluminum chassis, here: Amp Chassis
I built my GM70 amps on 12GA DD custom chassis, the output transformers weigh >10lbs - no deflection at all.
I am a very happy customer having had a fair number of custom chassis made DD, quick turnaround too. Highly recommended
"To argue with a person who has renounced the use of reason is like administering medicine to the dead." - Thomas Paine
Old 6th September 2012, 05:58 PM   #4
smbrown is offline smbrown  United States
smbrown's Avatar
I've had Dirty Dawg make several chassis now for me, they are outstanding! I add an 0.125" bottom plate & similar thick front panel and the things are very strong. Turn around time and customer service are great!
Old 7th September 2012, 10:36 PM   #5
Thanks guys, I've contacted DD and Yaeger and will likely wind up with one of each for diff projects. Thanks!
Old 8th September 2012, 02:34 AM   #6
Loren42 is offline Loren42  United States
I used an 0.050" thick Hammond chassis made of aluminum!
But, I mounted the transformers on a 1/4" plate aluminum that is bolted to that chassis and then I added a 1/4" vertical brace at the front of that transformer plate inside the chassis where you can't see it. It divides the tube audio section from the power supply section and it provides unparalleled rigidity to the whole thing.
My amp does not flex or sag and as you can see I have lots of iron on mine.
Click on the image for the full sized view.
All the metal is black anodized. Here is the bottom view with the bottom cover off:
Essentially, this is two mono blocks on a single chassis. It probably weighs 50 lbs.
Old 8th September 2012, 04:34 AM   #7
Pano is offline Pano  United States
Pano's Avatar
Be kind, please resize your photos for the web.
(I've done it for you)
Old 8th September 2012, 04:58 AM   #8
ChrisA is offline ChrisA  United States
Get one of these in 12 ga. That is a "deluxe" chassis. The metal is really thick and he makes them custom size for cheaper than Hammond. He can weld the corners if you ask but You don't need that if you plan to build a wood cabinet for your amp.
Amp Chassis
Here is one of his chassis in a wood cabinet I'm building. It was the first "test fit" and it worked the four bolts up from the bottom fit perfectly in the "clip nuts" in the chassis. I used #10 machine screws. The photo is of the rear. Later there will be some kind of from panel with exotic veneer
https://www.dropbox.com/s/h4nu7pdyae...%20chassis.jpg
Here is a photo of a "deluxe" chassis where I hope you can see the metal thickness. It is not the chassis design you want as this one was custom made for me for some portable gear. But see the metal thickness compared to screw head or nut on the switch. It is thick stuff.
https://www.dropbox.com/s/nes72pnq0w...gle%20view.jpg
One other thing. See how I have mounted the transformers in the above photo. This why is MUCH stronger then the stand up style. The iron core becomes part of the structure rather than a weight sitting on top. Also the lead wires are better protected. This amp is a low power stereo amp with EL84 power tubes but I would do a KT88 amp the same way
In either case be sure and buy a bottom plate too.
Old 8th September 2012, 06:06 AM   #9
TonyTecson is offline TonyTecson  Philippines
TonyTecson's Avatar
ga.12 is 1/8 inch thick......i have used ga#13 before...
planet10 needs your help: Let's help Ruth and Dave...http://www.diyaudio.com/forums/plane...ml#post5010547[B
Old 8th September 2012, 01:14 PM   #10
Burnedfingers is offline Burnedfingers  United States
Here is a thickness chart for you. 12ga is not 1/8 or .125 thick
You can easily beef up a thinner chassis by making what is called a top hat channel and have something that is lightweight and strong. its a simple process of making an offset on each side of a metal piece. See http://www.youtube.com/watch?v=j9wdotHTtZQ
What gauge enclosure for KT88 AMP?Hide this!Advertise here!
Strain Gauge jFET Pre-amp hazard500 Analogue Source 52 23rd July 2017 08:00 PM
4 - .7082 mH 12 gauge inductors -- $8 for one ___ 1 mH - 18 gauge -- 2 USD and others Jimmy154 Swap Meet 11 28th May 2012 10:27 PM
What gauge wire from sub amp to driver? Lewis Moon Subwoofers 1 22nd August 2009 11:39 PM
Need 2 find Source for 22 Gauge Coil .22mH & .56mH For Seas Trym avddreamr Multi-Way 1 1st March 2007 06:46 PM
Chip Amp Wire Gauge filholder Chip Amps 2 22nd March 2005 08:04 PM
Copyright ©1999-2017 diyAudio
