Old 6th September 2012, 01:51 AM   #1
Default Can you recommend a tube tester?
Greetings! I have need for a preamp tube tester and was wondering if anyone can recommend a good one to buy. I have heard the Maxipreamp testers are good - thoughts on this? Advice is desired. Thanks!
Old 6th September 2012, 04:44 AM   #2
maxi pre tester is fine. on the used front a mercury 1000 is a good tester and easy to calibrte. its a deal becuase the guts are famous brand but it gets little attention in a mercury case. last made in mid 70's so it supports a verywide portfolio of tubes. tube data is up on the net.
Old 6th September 2012, 02:17 PM   #3
Thank you, Speakerfritz. If anyone else has advice, particularly on the maxipreamp, I'd like to hear it.
Old 6th September 2012, 05:41 PM   #4
if money is no problem go for an amplitex
if you want something oldskool :
Neuberger 370 375 Funke W20 avro Mk 1 through 4 CT160
Dont forget the metrix U61
If your the King of DIY build your own
Old 6th September 2012, 05:53 PM   #5
Try to find Neuberger RPM370 RPM375 ... great testers and last for centuries ...
tubes.rs
facebook.com/tubes.rs
Old 6th September 2012, 07:58 PM   #6
Yeah those are Beasts, but unfortunately out of many peoples price range.
Your are a user right . could you tell me if the tester requires you to adjust the plate voltage once a tube starts pulling more current ?
I'd like to know just out of curiosity.
V4lve.
Old 6th September 2012, 08:26 PM   #7
The truth is, V4lve, I don't think so. I just need to test the tubes to see if they are good. I'm pretty new to working with tubes (very new!) but I just inherited a large number of old tubes and I think its wise to be able to test them.
Old 6th September 2012, 09:23 PM   #8
An Eico 666 or 667 is a good medium of the road tube tester , i use one as back up to my hickok 539C .
To be better one must be different ,but to be different is not necessarily better .
Old 7th September 2012, 08:49 PM   #9
i would opt for a I177 tvd7/u if your in the USA it tests quite alot of the old tubes. and is not nearly as junky as some of the other stuff. its also on the cheap end of the scale and gives pretty comparable measurements
Check your tube stash if their TV tubes dont bother you wont recoup your investment . except if some ultra rare sweep tubes ofc..
v4lve
Old 8th September 2012, 02:25 AM   #10
ArtG is offline ArtG  United States
In this day, I’d imagine that most of the tube testers in the US spend 99%+ of their time unused. I consider audio a hobby, and only a hobby. Should you just happen to be located anywhere near south central PA, you would be welcome to bring your tubes, and use my recently recalibrated TV-7 to checkout your “stash”. If it’s geographically impractical, perhaps, there are others that would extend the same offer.
WTB: Tube IMP or VTV Tube Tester or? bmenary Swap Meet 8 24th July 2011 10:39 AM
Help finding a tube tester for Stereo tube amps. Fasterdamnit Tubes / Valves 8 19th July 2010 01:43 AM
Recommend me a tube... Gordy Tubes / Valves 20 6th November 2009 05:30 PM
Please recommend a tube DAC to build. JayH3 Digital Source 1 26th May 2008 01:50 AM
Recommend an EL84 tube for HIFI ME2 Tubes / Valves 15 13th May 2007 03:13 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
