I've a pair of unknown transformers (may be 250/350W) in very good shape, I think they were recovered from a pair of inverter power supply (so unknown and probably unusable voltage ratings)
I've also some old PT that are in bad shape (and must bee rewound as to be usable) I'm wondering if the laminations of this transformers are usable to build bass and/or guitar OT (I need a big OT as to use some GU50 tubes I've for a very big amp) Thanks K |
#2 |
Probably, yes, OK for bass or guitar. Power laminations can sometimes be thicker than hi-fi OPT laminations, as the higher the frequency the thinner the lams.
#3 |
seen some microwave over transformers with very thin lamination's.
and those transformers you can get from most scrap yards easily. they go from 800watts to 1600watts+ so they could be suitable to rewind if you are worried about transformer size. |
#4 |
expert in tautology
most microwave xfmrs that I have seen have welded lams!
![]() And are of the split bobbin type... not the standard EI... _-_-bear
_-_-bear http://www.bearlabs.com [...2SJ74 Toshiba bogus asian parts - beware! ] -- Btw, I don't actually know anything, FYI --
#5 |
Take a die grinder to the weld. I've disassembled several small transformers by using a dremel tool.
#6 |
laminations that are 0.35mm thick are generally better than laminations of 0.5mm thickness...
http://www.elab.ph/forum/index.php?topic=32688.0 |
#7 |
Most power transformers (50/60Hz) are made from material that will have very high core material losses at audio frequencies. Generally above about 200 Hz.
400Hz power transformers are not made from the same material as 50/60 Hz ones. Good luck
Doug We are all learning...we can all help |
#8 |
In addition to usually being welded, MW transformers are designed for mainly harmonic current, accounting for their unusually high power rating for such core volume. The coils are usually saturated in very strong varnish and would have to be cut off. The core material is usually not very high quality even though they may be slightly thinner lams than everyday 60Hz transformers, and would have a lot of loss in the high kHz.. To reconfigure with full interleaving would take a ton of work to remove all the burrs after separating the welded I's from the E's. End result: probably not worth it for audio output.
#9 |
single ended opt's can use such welded MW transformers.......
#10 | |
As a rule of thumb just figure if you have a 100W PT that it will be good for only a 50W bass amp or a 100W guitar amp One question is the size of the window. A OPT will have many more turns of wire and it will have a few taps for 4, 8 and 16 ohm speaker loads |
| Opt laminations isolation | RuiR | Tubes / Valves | 16 | 1st May 2012 12:14 PM |
| How to clean transformer laminations? | rcbuck | Power Supplies | 15 | 22nd April 2012 06:46 AM |
| EI laminations in Europe | overdrajv | Tubes / Valves | 2 | 27th February 2009 08:09 PM |
| I Need Nickel Iron Laminations and Bobbins ! | Nikolas Ojala | Swap Meet | 3 | 7th April 2008 03:57 PM |
| E/I transformer laminations; why? | carpenter | Pass Labs | 41 | 19th September 2005 10:05 PM |
