diyAudio
diyAudio (http://www.diyaudio.com/forums/index.php)
-   Tubes / Valves (http://www.diyaudio.com/forums/tubes-valves/)
-   -   Amp ID Please (http://www.diyaudio.com/forums/tubes-valves/219098-amp-id-please.html)
24kilo 5th September 2012 08:28 AM
Amp ID Please
3 Attachment(s)
Just picked up an AMP, The only marking on the amp is a tag reading PA92-1732 the Trans has PA228B 138939 28536 the other trans has PA227 798909 or 809 . The output tubes are missing but assume they are el84 in a push pull, Has one 12ax7 one 6au7. It has volume knob and tone knob , it was a module for something else(console ,Tape deck?????). Outputs are 4 ohm 8ohm and 70v. I'm looking for a comparable schematic. I know this a shot in the dark but any help will be better than I have now.
Attachment 299774
Attachment 299775
Attachment 299776
ruben alstad 5th September 2012 10:44 PM
Most likely you wont find any info on that thing.
id rather open it and start to draw it from scratch if i was you.
Resources saved on this page: MySQL 18.75%
