#21 |
I have a grounding question.
The HV centre-tapped schematic shown above has a dot line on jumper J13 which bridges the PCB’s ground to the chassis. If I use the RCA jack isolated from the chassis. Do I jumper the J13? If not where do I ground the signal ground to the chassis? I want to use a LED to indicate the CCDA is on. What is the simple way to do it? |
#22 |
470 ohm 1 watt resistor in series with the led and then connect to the filament supply...
http://www.elab.ph/forum/index.php?topic=32688.0 |
#23 |
Thanks Tony for the LED connection.
#24 |
Just finished the building of the CCDA. After tuning the R9 to 6.8k, the sound is quite amazing. Good ambience and rich harmonics.
A special thanks to Jim who helped me getting a good quality transformer with less cost and the wiring of the heaters in voltage doubler configuration. The cost of the EDCOR-XPWR196-240 + shipping to Australia is USD108. The EDCOR is well build and solid with no buzz and hum. The CCDA is quiet. I deployed the 4 x 100uf 500v Black Gates from my dismayed kit built to be used in the CCDA project. They are happy to find a home to show their performance. Here are the pics for the CCDA. ![]()
| Transformer Out of Spec? | DreadPirate | Solid State | 16 | 20th December 2010 05:18 PM |
| transformer spec | skipper | Tubes / Valves | 3 | 29th January 2008 10:11 PM |
| Help with a transformer spec please? | Pbassred | Solid State | 1 | 18th June 2007 12:38 PM |
| Help for SE Main Transformer | baikostov | Tubes / Valves | 4 | 24th September 2006 08:01 AM |
| Spec on transformer for Aleph 5? | Tony D. | Pass Labs | 8 | 24th April 2002 12:49 PM |
