#11 |
Doing the math with the formulas presented by M. Blencowe, I adjusted the load resistance to the (for practical reasons) chosen 690 ohm kathode resistors.
Rload = (mu*Rk1,2 - ra) / 2 = (22*690 -1800) / 2 = 6690 ohm Quiescent current Iq = HT / (2*ra + 2*mu*Rk) = 285 / 2*1800 + 2*22*690 = 8.4mA Max undist voltage swing = 4* 8.4mA = 33.6 in 6690 ohm = 225Vpp or 80Vrms Output impedance ca 600 ohm. Even when optimising was an theoretical effort, the amplifier sounds finer with the lowered grid leak. Worth the trouble I'd say.
jaap |
#12 |
With Blencowe THD gets lower but the harmonic pattern gets worse. 2H lower but 3H higher.
#13 |
It's in anti phase to the output tube, wasn't it? That way lowering 3H would not harm.
I've just begon voicing but it has potential. First a smaller coupling cap as output impedance of the SRPP is that low. Bold bass response from that 150VA output, quite different to the AD1 sound I'd say
jaap |
#14 |
To my surprise as I was looking to use this valve in an OTL headphone amp, found it was not very linear:
http://www.bartola.co.uk/valves/2012...thd-benchmark/ Close to the top chart of the worst ones am afraid, however this is just a THD test... Cheers, Ale
"A mistake is always forgivable, rarely excusable and always unacceptable. " (Robert Fripp) http://www.bartola.co.uk/valves/ |
#15 |
Well, the charm is in the topology as SRPP operates in class A only. Under condition that both triodes contribute equally to the load, all even harmonics (not only 2H) cancel, resulting in minimum THD. This deep null is obtainable for a fixed load only and it does not clip pleasantly.
jaap |
#16 |
#17 |
In my opinion the best sonic results are when the idle current is about 20mA /section with a Vdc at 200-240 Vdc; -Vg at 2,5-3 volt; also the test on Thd are quite good.
I built a Gomes preamp with this specification and the results is fine. Ciao Walter |
#18 | ||
#19 | ||
![]() The 300V HT is too low to drive the SRPP with more current and the available power tranny was a design parameter, unfortunately. ![]() I thought about feedback for cancellation. If my numbers are right there's a 50Vpp margin for driving the power triode to full output. That would make NFB over the OPT to the driver input possible. Things seem to get too complicated to feed the anode of the power tube back to another node of the SRPP and still maintain some sort of even push pull operation.. Yet another possibility to lower or substantially diminish uneven harmonics would be a like-drive-like situation with a second SRPP. Anyone tried this? That would leave us with plenty of gain for overall feedback ![]() Quote:
Perhaps I'll have another look at a penthode driver and see with what I can come away with driving that miller capacitance. I married a C3G happily to a 2A3 but that's an easy load
jaap Last edited by disco; 10th September 2012 at 05:21 PM. |
#20 |
jaap |
| What do these curves mean? | Sunsun22 | Solid State | 2 | 7th February 2011 07:20 AM |
| How do these curves look? | astouffer | Tubes / Valves | 23 | 11th June 2009 09:52 PM |
| Derive Triode Curves from Pentode Curves? | dsavitsk | Tubes / Valves | 3 | 14th May 2007 06:10 PM |
| Curves, curves, and more curves | CarlyBoy | Tubes / Valves | 5 | 1st December 2006 10:11 AM |
| where's the curves? | bostonswoop | Multi-Way | 13 | 13th March 2006 12:32 AM |
