#11 | |
Btw: They are cheap, too, especially if you consider the RFT counterparts ECC 960 and ECC 962, respectively. Best regards! |
#12 |
Almost any triode will not be "too un-linear", but some are more linear than others.
#13 |
Well, if you had a CCS at the anode, and ran them at about 5mA and 300V B+, the result might actually be quite acceptable. Then again, the same operating conditions with a truly linear triode like the ECC99 from JJ Electronics results in very low distortion.
One thing often mentioned in the datasheets of these computer triodes is that they're prone to microphony. That's a thing to take into consideration when designing audio equipment. |
#14 | |
| very simple question | mail2vasu2004 | Power Supplies | 5 | 25th September 2010 10:36 AM |
| A simple question from a simple man. | inteificio | Solid State | 5 | 17th October 2005 03:00 PM |
| Simple C++ question | annex666 | Everything Else | 8 | 31st May 2004 03:03 AM |
| Simple answer required for a simple question... | rabbitz | Multi-Way | 4 | 31st August 2003 10:05 AM |
| A Simple Question | OMNIFEX | Multi-Way | 3 | 19th July 2003 08:11 PM |
