Triode Bias 101
Triode Bias 101
Old 3rd September 2012, 01:08 AM   #1
woodrough is offline woodrough  United States
Default Triode Bias 101
Hi! I am Kyle, and I am slowly amassing intel to construct an aikido phono circuit. I have a few principle questions on tube biasing. Although all the values are given to produce quality sound, I want to be able to backtrack the design and see where the 12ax7 tubes I select will sit on the charts. (sweet spots)
So the basics:
(1) on the chart how are the lines derived?
(2) what are the steps on selecting the proper values
(3) how to read the chart with my selected vales
(4) what are danger areas. (being that I want minimal distortion)
I have been trying to reed through Nazaroos bias chart, but there are some steps I have to understand before tackling this chart properly:
Golden Tubes: Tube Biasing 101 (Pt 2): 12AX7 bias chart!
I have been digging for the tutorials, so if anyone has a reference source for me to read through, that would be ultra!
Old 3rd September 2012, 03:43 AM   #2
TonyTecson is offline TonyTecson  Philippines
TonyTecson's Avatar
Triode Bias 101
How to design valve guitar amplifiers
planet10 needs your help: Let's help Ruth and Dave...http://www.diyaudio.com/forums/plane...ml#post5010547[B
Old 3rd September 2012, 03:16 PM   #3
ah! Excellent! I read through the 'Triode Gain Stage' chapter and got a pretty sweet overview on the biasing basics.
I also just landed on the page "The Shunt Regulated Push-Pull (SRPP)", looks just like the set up that the Aikdio shares. Currently this site is answering all my questions.
This whole site is the goldmine! Thank you Tony.
Old 3rd September 2012, 05:33 PM   #4
boywonder is offline boywonder  United States
boywonder's Avatar
education+diy
Old 4th September 2012, 06:39 AM   #5
TonyTecson's Avatar
Triode Bias 101
patrick turner is a good teacher....
Old 4th September 2012, 05:05 PM   #6
ohyes! I was originally looking at the PhonoDude design alot as well. One of the reasons of truly getting to the bottom of all this was to understand the differences between the mu-follower vs srpp (Aikido)
Alot of confusion started to arise when dealing at super low pre amp levels (Strange Ra numbers). I felt obligated to go back and verify and reproduce these models via LTspice myself.
Thanks for the forwarding of links! These are extraordinarily helpful. Slow reading and weeding
Triode Bias 101Hide this!Advertise here!
EL84 fixed bias PP Triode DrewP Tubes / Valves 23 24th November 2013 08:17 PM
Triode VS. UL bias gtrmkr Tubes / Valves 5 2nd May 2011 09:35 PM
Fisher X-101-C bias question Captn Dave Tubes / Valves 2 5th May 2010 02:24 AM
Cathode bias 6LU8 UL/Triode mashaffer Tubes / Valves 0 28th September 2008 11:45 PM
Pentodes, triode mode and grid screen dissipation 101 duderduderini Tubes / Valves 3 22nd September 2008 01:48 AM
