Choosing the right transformer
Old 2nd September 2012, 11:57 AM   #1
jeffreyrow is offline jeffreyrow
Default Choosing the right transformer
Hi, I need some help here. I have a toroidal transformer tht has 200, 220, 260, 280 and 320 volt outputs. I need a 400-0-400 supply from here. How do I do this. Btw my primary is 230 volts. Can someone pls help me. Thanks
Old 2nd September 2012, 01:13 PM   #2
costis_n is offline costis_n  Greece
Hi
I assume the schematic you have shows a 400-0-400 transformer. In that case, you don't have to follow it blindly, just use a solid state bridge and the 280 volt winding.
Old 2nd September 2012, 01:36 PM   #3
kevinkr's Avatar
I split this off from another thread as this question was OT there. Please start a new thread rather than diverting the direction of another one. Thanks...
"To argue with a person who has renounced the use of reason is like administering medicine to the dead." - Thomas Paine
Old 2nd September 2012, 05:40 PM   #4
razorrick1293 is offline razorrick1293  United Kingdom
for a 400-0-400 v supply, you are basically looking at 0-800, the most your traansformer can supply is 0-320. Im assuming you dont need a dual rail supply at +/-500v so you can use the 200 or 220 volt output and use a voltage doubling rectifier instead of a full wave/bridge rectifier.
Old 2nd September 2012, 05:52 PM   #5
Values/tubes on a dual polarity supply !
We usually only see a small -ve supply to bias the stages.
The values all behave as Nchannel only, there are no complements.
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 2nd September 2012, 06:07 PM   #6
boywonder is offline boywonder  United States
boywonder's Avatar
Jeffrey: Do you just need a +400VDC B+? ie, no -400VDC? Is this for a tube amp?
Old 2nd September 2012, 06:27 PM   #7
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
is this for a tube amp ? boy, are trying to be funny ?
but there are indeed quite many tube amp power supply trafos built/sold with symmetric voltages, and CT point
not that I know why exactly either
Old 2nd September 2012, 06:49 PM   #8
Centre tapped output transformer.
But both ends are connected to B+, not to B- & B+
regards Andrew T.
Old 2nd September 2012, 07:34 PM   #9
Pano is offline Pano  United States
Pano's Avatar
Right. What do you need for B+?
Old 2nd September 2012, 07:51 PM   #10
kevinkr's Avatar
I'm wondering if he was in fact looking for 800VCT AKA 400-0-400 in which case this transformer will not get him there, if OTOH he is looking for something close to the sort of output one could expect from 800VCT with a tube rectifier then the 320V tap with a solid state bridge rectifier might get him reasonably close. (or not)
Choosing the right transformerHide this!Advertise here!
Help with choosing a transformer? CarsonPratt Power Supplies 6 28th September 2011 10:24 PM
choosing transformer VA rating Tonge Power Supplies 5 30th July 2011 09:50 AM
Choosing an output transformer moonbird Tubes / Valves 110 17th April 2011 07:35 PM
Choosing transformer for desired wattage ervinl Power Supplies 2 25th August 2010 10:52 AM
Transformer Va choosing? pikkujöpö Power Supplies 7 25th April 2006 07:39 AM
Copyright ©1999-2017 diyAudio
