6J7 preamp
6J7 preamp
Old 31st August 2012, 12:19 PM   #1
6J7 is offline 6J7
Default 6J7 preamp
relatively new to tubes DIY, I built my first line preamplifier (capacitor output from plate) with 6J7.
It works well, then tried to connect transformers (LL1681) 13:1 to lower output impedance, I don't notice any improvement.
Actually the preamplifer is connected to a small trends audio class D amp (50K input), later it will be my 807 PP.
My question is:
Is there any interest to add a CF after the first stage ?
By the way, I have hum (50 Hz) problems with 6J7.. is this tube normally quiet when AC heated ?
Old 31st August 2012, 12:35 PM   #2
Osvaldo de Banfield is offline Osvaldo de Banfield  Argentina
Osvaldo de Banfield's Avatar
Location: Barrio Garay,Almirante Brown, Buenos Aires, Argentina
Try shielding the top cap (signal grid) wire.
Osvaldo F. Zappacosta. Electronic Engineer UTN FRA from 2001.
Argentine Ham Radio LW1DSE since 1987.
Old 31st August 2012, 01:02 PM   #3
6J7 is offline 6J7
Already using shielded wire, shield + hot soldered together at one side only between the 300K and 1K.
Old 31st August 2012, 03:42 PM   #4
Is the pin 1 of this 6J7īs also grounded? It is the metal envelope grounding pin. Is there any unbypased cathode high value resistor?
Old 31st August 2012, 04:22 PM   #5
6J7 is offline 6J7
Pin 1 is connected to pin 8 (cathode), maybe better to connect it to ground ?
300 ohms cathode resistor bypassed with a 220uF.
Here is the schematic.
Hum increased when turning up volume pot.. (quiet source and amp, I checked)
Old 31st August 2012, 05:11 PM   #6
6J7 is offline 6J7
Schematic correction, g3 externally connected to plate..
Old 31st August 2012, 05:16 PM   #7
DF96 is offline DF96  England
If hum gets worse as volume turned up then the hum is either coming in at the input, or it is capacitively coupled and responding to the changing ground resistance. With the input shorted, does the hum disappear when the volume reaches maximum?
Old 31st August 2012, 06:08 PM   #8
6J7 is offline 6J7
With input shorted, the hum is always at the same level.
With source (V-DAC) connected, the hum increase when turning up the volume..
Old 31st August 2012, 06:23 PM   #9
disco is offline disco  Netherlands
disco's Avatar
Move your psu ground from the 100uF cap to the C3 minusses (left and right tied together). Drop the 100 ohm to chassis. Any better?
Next, move the heater grounds there too. The way you had connected grounds made the heater potential run through your signal ground.
It's best to keep groundruns low ohmic by choosing thick solid copper wire or thinner braided copper wire or thinnest silver wire. Be aware for the witch hunt when using silver as it's only done for AF by audiophools (people depending on their ears only).
jaap
Old 31st August 2012, 06:33 PM   #10
Joe Roberts is offline Joe Roberts  United States
Joe Roberts's Avatar
Ground the grid lead shield to the chassis. Do not connect shield to hot anywhere.
If your pot has a metal back, ground that to chassis also--or ground the shield to the metal back then ground both to chassis.
I have had better luck with chassis grounds for this sort of thing than grounding to the signal ground. Is that chassis powder coated inside also? Make sure you scrape off some of the coating to get to bare metal.
It sounds to me as though this is an input wiring issue. A pic of actual wiring would be more helpful than the schematic.
6J7 preampHide this!Advertise here!
6J7 driver in WE91 like amplifier bobluis Tubes / Valves 9 10th February 2011 06:09 PM
Tube Preamp Popping on Source Input Change (?) / 6DJ8 Preamp On Chip Amps Travis Clarke Tubes / Valves 3 16th October 2008 04:52 AM
Guitar Preamp = MIC Preamp = other preamp ,,are they all same? Paswa Instruments and Amps 1 12th March 2008 05:16 PM
twisted pear Preamp/other suggestions for Preamp kit LukeDuke Chip Amps 1 1st February 2008 09:57 PM
Electret mic preamp - will phono preamp work? darthmullet Analogue Source 6 12th October 2007 07:32 AM
