6J7 preamp
6J7 preamp
Old 11th September 2012, 11:25 AM   #101
6J7 is offline 6J7
6J7's Avatar
I tried a new power supply setup (disco): 50uF > 100R > 50uF > choke > 200uF
- output caps (0.68uF, too much) are now in aluminium enclosure
- 50 Hz hum seems to be gone
- welcome to 100Hz hum
Although, it's not loud (full gain, step down transformers not yet installed) and hum is now "clean", no bzzzzzz anymore.
Not the most important thing at this time but sound is 100% boring, I'll try with bypassed cathode resistor again.
About 135V on plate, 20K load and 3.3V with led bias, not a good operating point. But I expected a fat mellow sound, not at all ! thin.. (mid-band gone ?)
I am thinking to not use anymore these big capacitors and go for electrolytics (short wires).
And two die-cast Hammond enclosure, one for the PS, the other for the voltage amp.
Old 13th September 2012, 01:44 PM   #102
6J7 is offline 6J7
6J7's Avatar
Hello,
hum problems are now almost solved.
But there is a ground loop (?) when adding Sowter 8920 at the input. Screen (black) has no effect, connected or not.
When connecting the input ground (orange) to starground, it's ok.
Did I miss something ? an isolating input transformer has no interest if input ground is connected to secondary ground, right ?
6J7 preampHide this!Advertise here!
6J7 driver in WE91 like amplifier bobluis Tubes / Valves 9 10th February 2011 07:09 PM
Tube Preamp Popping on Source Input Change (?) / 6DJ8 Preamp On Chip Amps Travis Clarke Tubes / Valves 3 16th October 2008 05:52 AM
Guitar Preamp = MIC Preamp = other preamp ,,are they all same? Paswa Instruments and Amps 1 12th March 2008 06:16 PM
twisted pear Preamp/other suggestions for Preamp kit LukeDuke Chip Amps 1 1st February 2008 10:57 PM
Electret mic preamp - will phono preamp work? darthmullet Analogue Source 6 12th October 2007 08:32 AM
