Driving a Behringer INuke Nu1000 - diyAudio
Old 31st August 2012, 03:34 AM   #1
Default Driving a Behringer INuke Nu1000
I wanted a preamp for this stereo PA. I have a Fenderish 3 stage style ECC189 based preamp driving my 100W Linsley Hood mosfet power amp, it has plenty of signal, enough to crank the PA. Tried this preamp with this Behringer stereo PA and it seems it's not enough to deliver its maximum output power (plugged into a 4x10 cab wired 2 by 2, so it would be 300W per speaker pair), and led peak indicator goes up to red (don't know if it's a signal or a peak detector). Any info about this power amp sensitivity?
I'm thinking on a 6SN7, maybe 6SL7, or just 12AX7 based 3 stage preamp a-la-Fendre, I think it will be enough signal to drive the amp, my ECC89 preamps has about 90V DC supply, and it's quite clean (even with vol at max doesn't distort).
Any ideas?
Behringer iNuke NU3000 Measurements bolserst Class D 107 19th June 2017 10:15 AM
Behringer iNuke NU3000 w/o any fan...? Soldermizer Class D 157 11th January 2017 05:28 AM
OB with vintage Seas and Behringer Inuke DSP zmyrna Full Range 2 23rd April 2012 09:36 AM
nu1000 and mono subwoofer tvojmuuc Subwoofers 2 9th December 2011 10:23 AM
Behringer DEQ ok driving multiple loads brucemck2 Subwoofers 0 18th January 2006 09:49 PM
Copyright 1999-2017 diyAudio
