Lowering cost of audio output transformer - diyAudio
Old 27th August 2012, 04:55 PM   #1
pilovis is offline pilovis  Italy
Default Lowering cost of SE audio output transformer
Given that the cost of S.E. audio transformers has become prohibitive, I'm trying to use modified line transformers at place of class A audio transformer.
Laminated core as shown below with insulating paper between the two groups of laminations:
Primary winding divided into two only sections, the same for the secondary, wound according to the following scheme:
"First section primary, secondary first section, second section primary, secondary second section."
Examples:
5K/8ohm transformer (6V6, EL34, ECL86, EL84, KT88 - S.E.) = 110+110 Vac primary - 4.5+4.5 Vac secondary
3K/8ohm transformer (6L6, 807 - S.E.) = 110+110 Vac primary - 6+6 Vac secondary
800/8ohm transformer (EL/PL504 - S.E.) = 110+110 Vac primary - 12+12 Vac secondary
This construction and winding scheme (standard voltages) greatly reduces the cost of the transformer (I pay for it only 15 Euro for a 40 VA custom transformer).
The first two prototypes will be available in two days so I will test them to see if they work (hope so...)
Old 27th August 2012, 04:58 PM   #2
GCA is offline GCA  United States
That could be interesting.
Old 27th August 2012, 05:05 PM   #3
kevinkr's Avatar
I'm quite sure it will be very interesting.
Toroidal power transformers have a good track record in PP and parafeed applications with tubes having extremely low rp like the 6AS7/6080..
"To argue with a person who has renounced the use of reason is like administering medicine to the dead." - Thomas Paine
Old 27th August 2012, 05:16 PM   #4
TheGimp is offline TheGimp  United States
TheGimp's Avatar
PP or SE transformers?
Old 27th August 2012, 05:22 PM   #5
SE transformers, PPs do not have direct current saturation so do not need special insulated core as shown above.
Old 27th August 2012, 05:54 PM   #6
ruffrecords's Avatar
I thought mains transformers had no gap. Are these being built with or without a gap??
Cheers
Ian
Old 27th August 2012, 05:59 PM   #7
Richard Ellis's Avatar
Location: Mar del Plata, a BIG seasonal getaway city, can see the Ocean from our residence.
Of course they will be built with a gap....The fun experiment will be setting the gap...I always thought one could use a roll of Teflon tape to experiment with gapping..
__________________________________________________ ____Rick.........
Old 27th August 2012, 06:02 PM   #8
Cheers
Ian
As you can see on the above picture there is a gap between "E" laminations and "I" laminations, insulated with paper.
Old 27th August 2012, 06:03 PM   #9
diyAudio Moderator Emeritus
jean-paul's Avatar
Thread title:
Suggested thread title:
Making good SE output transformers at lower cost
Reason: price should not be the only driving factor. Quality is prevalent in audio DIYing since the device will be more expensive than ready built devices anyway.
It's only audio. Member of the non modular PCB design committee
Old 27th August 2012, 06:10 PM   #10
leadbelly's Avatar
I actually still don't understand what you are you doing. Are you just ordering a special version of a standard model transformer from a manufacturer, i.e. you instructed them to build you one of their standard power transformer models except to create a gap using paper? Or do you have a transformer in hand that you took down to the laminations without destroying the bobbins and are reassembling it with a gap?
The whole problem with the world is that fools and fanatics are always so certain of themselves, and wiser people so full of doubts. Bertrand Russell
Below-Cost Sale: Japanese Z11 Core SE Output Transformer Pair with Thick Alu. Covers DIY Hifi Supply DIY HiFi Supply 6 7th February 2012 07:12 AM
Lowering voltage output of transformer TGRANT Tubes / Valves 8 17th January 2007 10:29 AM
Lowering the output impedence of this dac's output georgehifi Digital Source 14 31st October 2006 07:05 PM
Lowering clock output audiokid25 Digital Source 4 6th June 2005 07:08 PM
Lowering HV secondary on Power Transformer edsmith Tubes / Valves 4 11th February 2005 07:38 AM
Copyright 1999-2017 diyAudio
