Old 27th August 2012, 06:13 PM   #11
pilovis is offline pilovis  Italy
Originally Posted by jean-paul View Post
Thread title:
Lowering cost of SE audio output transformer
Suggested thread title:
Making good SE output transformers at lower cost
Reason: price should not be the only driving factor. Quality is prevalent in audio DIYing since the device will be more expensive than ready built devices anyway.
I pay these custom transformers only 15 Euro each (40VA), it worth a try
Old 27th August 2012, 06:16 PM   #12
Originally Posted by leadbelly View Post
I actually still don't understand what you are you doing. Are you just ordering a special version of a standard model transformer from a manufacturer, i.e. you instructed them to build you one of their standard power transformer models except to create a gap using paper? Or do you have a transformer in hand that you took down to the laminations without destroying the bobbins and are reassembling it with a gap?
yes, I am ordering a special version of a standard model transformer from a manufacturer and instructed them to build one of their standard power transformer models except to create a gap using paper and wound them according to the winding sequence described above.
Old 27th August 2012, 07:37 PM   #13
Cassiel is offline Cassiel  Libya
Cassiel's Avatar
And they charge you only 15 euros for a custom job? Wow, that's cheap. What's the price of their power transformer? It can't be cheaper. Something doesn't add up here.
Hello
Old 27th August 2012, 07:50 PM   #14
They sell a standard 40 VA transformer for 15 Euro plus VAT, for the same price the built me the prototypes.
I also asked them to built me a custom line trasformer (winding shielded) of 150 VA: pri. 220V / sec. 125-0-125 0.5 A, 6.3V 3A, 19V 1 A, I paid it 40 Euro plus VAT.
Their website: http://www.pattrasformatori.com
Old 27th August 2012, 09:48 PM   #15
ilimzn is offline ilimzn  Croatia
Hopefully you are aware that a gapped core suitable for a 40VA transformer will be able to pass only a fraction of that power at audio frequencies... and if it's wound for voltage transformation derived from a mains transformer calculation, they will also have way too low inductance of the primary to even work at mains frequency, let alone lower. This ill improve with lowering the gap width but then maximum DC current will fall too...
Below-Cost Sale: Japanese Z11 Core SE Output Transformer Pair with Thick Alu. Covers Brian Cherry DIY HiFi Supply 6 7th February 2012 07:12 AM
Lowering voltage output of transformer TGRANT Tubes / Valves 8 17th January 2007 10:29 AM
Lowering the output impedence of this dac's output georgehifi Digital Source 14 31st October 2006 07:05 PM
Lowering clock output audiokid25 Digital Source 4 6th June 2005 07:08 PM
Lowering HV secondary on Power Transformer edsmith Tubes / Valves 4 11th February 2005 07:38 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
