Old 27th August 2012, 10:27 AM   #1
bullpeters's Avatar
Location: Right next to beach, a potatoe toss to the whitewater
Default morgan Jones HT caps & Anode Loads
If I am not wrong,the great Morgan Jones, who I have read from back to front and back again several times espouses "Polypropylene HT Capacitors and Wire Wound Aluminum Cased Anode Loads", in his EL84 amplifiers (my favorites)
I have a deep respect for MJ but rocking horse poo looks common compared to the above. I have only the entire WWW to look in but i cant find either in the values that would seem desired for the stated purpose. What gives
Old 27th August 2012, 11:56 AM   #2
SY's Avatar
Don't know about Oz, but here in the US, they're common as can be- standard and inexpensive items at places like Mouser and Digikey.
If there's a sucker born every minute, where do the rest of them come from?
Old 27th August 2012, 01:55 PM   #3
Polypropylene caps are common everywhere - just look for motor run. Not motor start by the way.
Wirewound resistors sound great. I prefer the sound of the vitreous enamel types e.g. Welwyn green types to the aluminium clad ones. Depends on the wattage, but I'd avoid aluminium clad if I had an alternative.
Old 27th August 2012, 04:25 PM   #4
kevinkr's Avatar
Aluminum clad are OK as bypassed cathode resistors and in power supplies, but as has been suggested perhaps best avoided in the audio path proper. I like both Mills non-inductive types and the green Welwyns mentioned.
"Extraordinary claims require extraordinary evidence." - Carl Sagan
Old 27th August 2012, 04:51 PM   #5
zigzagflux's Avatar
My vote for the capacitors. Save the motor runs for when you need high capacitance values. For that first small cap after the rectifier, or the ones he recommends around DC chokes, these can't be beat. They are shown in stock at Mouser's Australian store.
http://www.cde.com/catalogs/940C.pdf
Old 28th August 2012, 05:05 PM   #6
So, a cathode resistor in not in the audio path?
Old 28th August 2012, 05:18 PM   #7
kevinkr's Avatar
Note the operative word "bypassed" The AC signal current in this instance flows through the bypass capacitor until Xc is appreciable compared to the cathode resistor.
Note I'm more than likely to use fixed bias in a situation where this sort of cathode bias resistor might be used.
Morgan Jones' RIAA Pre-Amp skajam66 Tubes / Valves 2 4th January 2011 04:04 PM
Help with Morgan Jones headphone amp trevorjn Headphone Systems 7 6th December 2009 10:52 PM
looking for morgan jones phono amp schematic w00t Tubes / Valves 2 23rd July 2004 07:51 AM
Morgan Jones H/P Amp problems PLEASE HELP NotInTheMafia Tubes / Valves 13 21st January 2004 12:33 AM
Morgan Jones tube amp and equalization Prune Tubes / Valves 4 13th May 2003 07:00 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
