SET-NO FEEDBACK amplifier performance
Old 26th August 2012, 10:02 PM   #1
fotios is offline fotios  Greece
fotios's Avatar
Default SET-NO FEEDBACK amplifier performance
Hello
I ask your forgiveness for the new thread but no one replies me in the most important thing for me in the other thread. So the only solution I had was to open a new thread for a clear technical discussion.
I built a SET amplifier without any feedback using the same circuit of “Glass House 300Bse” stereo amplifier designed by Andy Groves (Audio Note) on which the only modification I did was to convert it in monoblock. To this I simply added a second 300B in parallel with the single one of the original circuit and I converted the output transformer primary to 1.5ΚΩ/350mA.
What interests me is if the performance of amplifier as is presented in the three FFT plots is acceptable for its class of design. In the first are presented all main parameters at 1Wrms/8Ω “Un – Weighted”, in the second the same but in full output power at 8Ω “A – Weighted” and in the third the frequency response (or bandwidth -3dB). No filters have been used in FFT analysis (e.g. number of Harmonics), the vertical (Y) scale is in dBV so you can make a direct estimation of harmonics level in real Volts (0dBV=1Vrms) and only the frequency response plot is expressed in dBr for a reference max amplitude at 0dB. In all plots the FFT smoothing window used was “Kaiser 6”. For the frequency response as stimulus used White Noise.
Thank you for any comment positive or negative.
Best Regards FOTIS ANAGNOSTOU
Old 26th August 2012, 10:11 PM   #2
ruffrecords is offline ruffrecords  United Kingdom
ruffrecords's Avatar
Looks fairly typical to me. Over 1% THD distortion at 1W, mostly second and third harmonics with the harmonics falling off nice and rapidly. When the power is raised by 10dB the THD rises by about the same amount but the higher harmonics are much more relatively prominent which is an indication of the onset of clipping.
Cheers
Ian
Old 27th August 2012, 04:37 AM   #3
fotios's Avatar
Cheers
Ian
Thank you so much Ian for your detailed technical review. You should know that is precious to me, because this amplifier is the first tube project that i built in my life. This well focused review has enlighten me a lot.
Thank you again.
Fotis
Old 29th August 2012, 03:56 PM   #4
palmas is offline palmas  Portugal
looks quite good, even too linear for a SET...
Congrats
Old 29th August 2012, 04:42 PM   #5
fotios's Avatar
Congrats
Thank you so much palmas for your kindness to look on the FFT plots and above all for your positive comments + congrats
As a newbie in tubes, i feel a big relief after your confirmation - as well this of ruffrecords - that i have obtained a good result.
Fotis
SET-NO FEEDBACK amplifier performanceHide this!Advertise here!
Plate-Grid feedback: How to get better than DHT performance from cheaper tubes SpreadSpectrum Tubes / Valves 22 24th January 2016 12:46 AM
SET amp using Triode-FET complementary feedback pair ? Bigun Tubes / Valves 20 9th June 2013 02:20 PM
6c33 SET (my next project). Need some feedback rvrazvan Tubes / Valves 52 20th July 2012 08:27 AM
DC off-set versus no negative feedback... philmagnotta Solid State 21 22nd December 2010 04:57 AM
Iron set for Paraglow (2A3) SET amplifier Alain Favret Swap Meet 1 19th March 2004 06:23 AM
Copyright ©1999-2017 diyAudio
