Console Amplifier Pull:Voltages over Spec - Page 2 - diyAudio
Old 27th August 2012, 04:20 PM   #11
kevinkr's Avatar
Originally Posted by TheGimp View Post
Kevinkr, they specify a VTVM for measurements. The input impedance would have been greater than 1MEG ohm, so readings are accurate.
Measurements would have been taken with a line voltage of 115VAC. Modern lline voltage of 125VAC would result in an increase in voltages of 1+((125-115)/115)=1.08 or 8% increase in all readings.
Not having the original schematics I didn't know about the VTVM, but good to know. Most of the Sams (and other) schematics I have seen in this time frame specified an analog volt meter.
Line voltage has crept up quite a lot since this amp was designed, and this can cause all sorts of problems with marginally specified components in the power supply. My line voltage never drops below 117V and usually hovers around 123V except during the dinner time hours where it tends to drop. (Always horribly distorted sine wave.. )
"To argue with a person who has renounced the use of reason is like administering medicine to the dead." - Thomas Paine
Old 27th August 2012, 05:11 PM   #12
TheGimp is offline TheGimp  United States
TheGimp's Avatar
There is a note at the bottom of the multiplex adapter section. It threw me at first as well till I saved the schematic and looked at it expanded.
That is a good point about some schematics using low Ohms/Volt meters. It is easy to forget a time when they were common.
WOW! I just looked up the venerable Simpson 260 and it is only 20Kohms/Volt.
Old 17th September 2012, 04:15 AM   #13
heyraz is offline heyraz  United States
Greetings again,
As anticipated (thanks again for explaining the calculation) a 22k resistor from R37 to ground made up for the missing tuner section resulting in voltage measurements more closely matching the schematic.
There is however, one thing I'm not clear about, and that's what voltage/Pin I should be targeting when using the Output Tube Bias Control, Pin 2 (G2) or Pin 3 (K1,G3). The only time the voltages will match the schematic values is when line voltage is 112VAC. At my available 117VAC, if I set Pin 2 to 21V, Pin 3 will be greater than 33V. Conversely, if I set pin 3 to 33V, Pin 2 will be less than 21V. A conundrum for this newb.
That being said, I think this amp sounds incredible. It's rock solid, clear as a bell and fun to listen to. I've rolled a couple of different sets of input and output tubes and am currently enjoying Tele ECC83's and Amperex EL84's.
A real pleasant surprise. Thank you all again for your help.
Rich
Old 17th September 2012, 01:54 PM   #14
20to20 is offline 20to20  United States
20to20's Avatar
Originally Posted by heyraz View Post
Greetings again,
Rich
With higher voltages all around it makes sense that your cathode to G1 will also be different from the schematic. The important ratio for them is to be slightly wider apart now. The G1 needs to be at least 12v less than the cathode, as designed. As the B+ for everything is higher the current through the tube will be higher, too, so under these conditions it would be advisable to have 13v -15v lower for G1 than cathode. So if you have 20v and 34v that's good.
Old 17th September 2012, 02:16 PM   #15
jane is offline jane  Norway
jane's Avatar
Between R37 and chassis ground : I measured 353 instead of 275 (implying to me that R37 is shorted)
It indicates that a tuner is not connected to the amplifier (no tuner no current through R37).
Life is hard - Then you die.
Old 17th September 2012, 03:54 PM   #16
Rich,
Thanks for that advice. I'm analytical by nature, so I like to understand why I'm doing something before I do it. As mentioned, I still consider myself a newb and only realized just a few moments ago that this is a "fixed bias" design. The "output tube bias adjust" control on the amp mislead me.
A difference of at least 12 volts exists no matter how much voltage is applied to the cathodes, so I assume all is well. Since the wiper of the bias adjust is connected to the control grids, I assumed that was the point of measurement and became concerned when I noticed the cathodes were slightly hotter. I guess I'll have to play with different levels to decide what sounds best.
Thanks. Richj
Western Electric console pull Pano Full Range 10 4th May 2011 03:46 AM
Amplifier power supply voltages audio_tony Solid State 10 18th December 2010 04:54 PM
Need help/advice on a problem with console amplifier IG81 Tubes / Valves 39 22nd September 2010 05:05 PM
Oddball Console Amplifier kevinkr Tubes / Valves 17 29th July 2008 10:16 AM
Amplifier operation voltages Eccu Solid State 3 7th February 2002 02:12 PM
Copyright 1999-2017 diyAudio
