My 2 year old EL34B based amp arced on the right channel for the first time. I was measuring the db output with my little dbmeter I was about 10 feet away. I heard one static crackle, one of the EL34B tubes on the right channel arced between two pins in the front of the tube. I was not close enough to see what pins they were. But close enough to see the arc then the bottom of the EL34B glow brightly for a second. I was close enough to shut down right away. I am driving 4 ohms speakers off the 4 ohm taps. Everything was sounding great at 90db. After two minutes I turned the amp on again and listened at 30% volume. Sound is fine, bias voltage is fine on all 4 EL34B tubes. I listened for 30 minutes, no arcs and the EL34B apperars to be operating normally. I have a 1/16" gap between the bottom of the final output tubes and the sockets. Should I force the tubes to be flush with the sockets ?
Have an of you seen this before ? I used to see this when a cap is failing on an old tube radio, but when it started arcing it didn't stop until I replaced a dead capacitor and rectifier tube. My 55w EL34B amp stopped arcing as soon I lowered the output volume and input signal level. |
#2 |
Valves should usually be fully inserted into their sockets, to ensure good contact. It is possible that you have seen the effect of parasitic oscillation.
#3 |
I've been listening to tunes through my el34 based amp with the wife. Volume is at 30%
. Its been 1hr now and no problems. It still sounds great! |
| UCD Based Fully Differential Full Bridge 450W RMS Amp | classd4sure | Class D | 90 | 27th August 2012 07:48 PM |
| Sweet Peach EL34b Amp - Distortion? | wirralguy | Tubes / Valves | 53 | 18th February 2012 11:53 AM |
| Building something better with a Chinese SE EL34B Amp DIY Kit | VictoriaGuy | Tubes / Valves | 19 | 28th June 2011 07:52 AM |
| MENG Series "EL34B" Integrated Amplifier | stevenscoffee | Tubes / Valves | 2 | 8th July 2008 07:10 AM |
| Transformer-based volume control | wboyd | Analogue Source | 4 | 18th August 2004 04:57 PM |
