Custom power tranny specs recommendations for 300B pse monoblocs
Old 25th August 2012, 11:50 AM   #1
duderduderini is offline duderduderini  Australia
Default Custom power tranny specs recommendations for 300B pse monoblocs
Hey
I will be building Parallel Single ended 300b amps and want to order 2 power trannys for them.
I will be using Pete Milletts dc regulator for all the valves.
If i want say 6.3v at 2 amps dc regulated, what output should the power tranny have to account for regulation and losses?
Ditto for the 300bs... I want 5 v at 1.5 amps (x2 of course) so what value should i ask for there?
I am a bit hazy on this so I would appreciate help.
Finally given I will be using cathode bias for the 300b's what would be recommendation for HT supply
Thanks again
Nick
"Better to say nothing and keep them guessing than to speak and remove all doubt."
Custom power tranny specs recommendations for 300B pse monoblocsHide this!Advertise here!
FS: Audio Note IE Transformers for 300B/2A3 monoblocs Tax Swap Meet 2 22nd April 2011 10:37 AM
samples of 300B in pse or pp jarthel Tubes / Valves 22 20th March 2007 01:52 AM
Drd 300b Pse JC951t Tubes / Valves 0 26th December 2006 08:58 AM
Help with tranny specs Turboegt Solid State 2 14th December 2003 12:48 AM
300B Push-Pull and PSE mozfet Tubes / Valves 1 5th August 2002 07:32 PM
