Winter upgrade project - new heating unit - diyAudio
Old 25th August 2012, 12:11 AM   #1
Default Winter upgrade project - new heating unit
audio room has 10" concrete walls and a poured slab as a floor. even with a raised floor insulated with foam and all walls insulated with foam....still gets cold. this should help. 48 6550 tubes.
File Type: jpg Screen shot 2012-08-24 at 4.54.47 PM.jpg (46.5 KB, 95 views)
Old 25th August 2012, 12:13 AM   #2
woltan 1250 tube amp. built in 1998. at the time, the largest production tube amp. 1200 watts per channel. 30amps draw at full power. 9 amps draw at idle.
File Type: jpg Screen shot 2012-08-24 at 4.54.10 PM.jpg (44.0 KB, 88 views)
Old 25th August 2012, 12:28 AM   #3
kevinkr's Avatar
Should keep you quite warm.. The really big VTL amps don't seem to like a lot of stuff below 10Hz or so, so make sure if playing vinyl there is not a lot of subsonic energy in the output of your pre-amplifier.
What sort of speakers are you driving with these? Seems like an old pair of Apogee Divas or Grands would be just the ticket with this kind of power.
"To argue with a person who has renounced the use of reason is like administering medicine to the dead." - Thomas Paine
Old 25th August 2012, 12:36 AM   #4
My speaker portfolio is pretty limited...don't think I have the ideal speakers for these...so some buying and selling will probably happen.
Old 25th August 2012, 12:42 AM   #5
kevinkr's Avatar
Think really big and power hungry.. Check out the larger VMPS systems as well the Infinity Reference series.. Should be a lot of fun..
New project... Yamaha RX396 Upgrade Adrculda Solid State 10 24th August 2009 05:42 AM
Trying to upgrade my rel stentor bass unit mojogoes Subwoofers 11 6th February 2008 09:46 PM
Upgrade stock head unit amplification IC groover1234 Car Audio 3 8th October 2007 06:09 PM
Suggestions for winter DIY project... ssabripo Subwoofers 38 29th March 2006 01:17 PM
Lovely Winter look grataku Everything Else 16 24th December 2002 08:18 PM
Copyright 1999-2017 diyAudio
