6KM8 amp
6KM8 amp
Old 23rd August 2012, 09:43 PM   #1
engels is offline engels  Israel
engels's Avatar
Question 6KM8 [triple plate tetrode] amp
6KM8!!!
For some time I wanted to make something with this tube.
It's a triple-plate sharp cutoff tetrode (+ diode but who cares), datasheet suggests "complex-wave generation".
http://www.tubebooks.org/tubedata/hb...art_2/6KM8.PDF
I have never seen any circuit with this tube so I have no idea how it should work. Pictures? Someone?
I wanted to start with an oscillator, but now I think I'd make a guitar SE amp to see how it works first. The idea is to have the source signal split into two or three (with different voices/colors) and then get the three channels back together before the power stage.
Something like input -> 6KM8 -three parallel 6C4's or 6AB4's -> 6AQ5.
The choice of the other tubes is just what I have lying around and not your typical 13AX8 whatever.
I've found that the guitar amps I like usually have parallel preamp channels that make it sound wider. Less distortion, more fatness. So I hope with 6KM8 splitting the signal into three it should give it certain tone complexity.
Anybody has something to say?
I would really love to see some circuits with 6KM8 - if there are any documents.
Old 26th August 2012, 10:14 PM   #2
engels's Avatar
anyone?
Old 26th August 2012, 11:14 PM   #3
TonyTecson is offline TonyTecson  Philippines
TonyTecson's Avatar
6KM8 amp
connect the 3 plates, 100ohm from screen to plate and use that tube as a triode.....
planet10 needs your help: Let's help Ruth and Dave...http://www.diyaudio.com/forums/plane...ml#post5010547[B
Old 27th August 2012, 12:36 AM   #4
astouffer is offline astouffer  United States
astouffer's Avatar
Sounds like a simple enough project to breadboard, give it a try. You could use a 6ML8 triple plate triode with one common cathode to mix the 3 signals back in. About the only place you'll see a 6KM8 used is electronic organs. It caught my interest a few years ago and I did finally find a schematic. Now where did it end up...
6KM8 ampHide this!Advertise here!
Modify & build out (2) Western Electric 300B / 2A3 Hammond monoblock amps & UTC LS-5 quality sound Tubes / Valves 0 9th May 2009 03:59 PM
Krell KSA 80 bias & dc offset check & adjust procedure Clouseaupte Solid State 3 9th August 2007 09:39 AM
DIY-AMP <ZAS> Low THD & IM high bandwith murphy Solid State 18 30th December 2005 10:28 AM
