Basic Bias Question for PP Amp - diyAudio
Old 22nd August 2012, 03:03 AM   #1
Sherman is offline Sherman  United States
Default Basic Bias Question for PP Amp
I'm putting together the pieces for yet another KT88 P-P amp with Mullard topology. I am designing the power supply and have a basic question about setting up the bias system. Virtually all the schematics I've examined show a single bias pot for each pair of output tubes, however I've heard several recommendations for using a separate pot for each tube. My question is basically is it worth it to set up the bias circuit with four pots or am I just overly complicating things?
--Sherman
--Sherman
Old 22nd August 2012, 03:23 AM   #2
HollowState's Avatar
I always use separate individual bias pots for each tube. I want the control they provide. With only one pot for a pair, you either need to closely match the tubes or provide a balance pot, which brings you back to two pots.
1944: 18 year olds storm the beach of Normandy into almost certain death.
2016: 18 year olds need a safe place because words hurt their feelings.
Old 22nd August 2012, 06:59 AM   #3
cerrem is offline cerrem  United States
cerrem's Avatar
There is always pros and cons with any methods...
With a pot on each tube.... you are effectively applying a delta in bias grid voltage.... For example -40 on one tube and -48 on the other tube...
Now you have disimilair clipping points....or uneven headroom....
Feedback can fix some of this but...it still is not correct...
I prefer to keep the bias voltage matched....but instead turn down the heater voltage on the stronger tube.... I have adjustable heater voltage on one valve socket....and i place the stronger valve at this socket..
Make sure to really measure the true PLATE current in SERIES with the plate wire.....not CATHODE current measurements or shunt by-pass methods...
Chris
Old 22nd August 2012, 04:41 PM   #4
Palustris's Avatar
Individual bias for each tube is a little more complicated, but that's the way I would go.
Old 23rd August 2012, 07:02 PM   #5
Thanks for the input! I'm redrawing the power supply to provide individual bias.
--Sherman
Basic op amp question Tube Noob Chip Amps 3 22nd November 2011 06:03 PM
Big Boss: a simple and basic el84 PP amp in progress Lingwendil Tubes / Valves 6 3rd June 2009 04:24 AM
Finding bias point in PP fixed bias beamnet Tubes / Valves 14 7th December 2008 02:25 PM
amp question basic rec rebith75 Solid State 3 16th March 2007 06:43 PM
Very basic chip amp question leadbelly Chip Amps 3 13th August 2003 05:25 PM
Copyright 1999-2017 diyAudio
