Modification of 300B SE Amplifier
Old 21st August 2012, 05:24 PM   #1
Angelpat is offline Angelpat  Hong Kong
Default Modification of 300B SE Amplifier
Any idea if changed the input stage 6SN7 from SRPP to parrallel connection. Is that help to reduce the over gain of the circuit? Do concert if the current of the input stage will be more than the driver stage (maintain the SRPP).. Should I maintain the 1.5K cathode resistor as is in order to keep the same current flow over the input stage... I have to calculate the new value of the plate resistor afterward.
Please share comment.
thanks!
300BSch (Patrick) | Flickr - Photo Sharing!
Old 21st August 2012, 05:26 PM   #2
original schematic enclosed
Old 21st August 2012, 07:49 PM   #3
Dimitris AR is offline Dimitris AR  Greece
You can reduce the gain by simply remove the bypass capacitor in the first SRPP stage.
Old 21st August 2012, 09:32 PM   #4
Palustris is offline Palustris  United States
Palustris's Avatar
You can remove the entire first stage by connecting the input to the second SRRP stage.
Old 22nd August 2012, 01:37 PM   #5
I did tried to remove the bypass cap fron the input tube and yes, the gain reduction achieved but it lose the "mid" gthe high and the bass are both acceptable) ... May be too much reduction that I'm not sure and thus consider making something in between.
Old 22nd August 2012, 03:54 PM   #6
palmas is offline palmas  Portugal
What is the supply voltage?
Old 22nd August 2012, 05:13 PM   #7
the plate of the lower tube : 185Vdc
cathode of lower tube : 4Vdc
Old 22nd August 2012, 05:14 PM   #8
the top triode plate voltage?
Old 22nd August 2012, 05:28 PM   #9
370Vdc
Old 23rd August 2012, 10:54 AM   #10
370Vdc
With that voltage you can use the 6SN7 in a griunded cathode configuration, with both triods in parallel (Rplate=10k to 12k and Rcathode=1K and 8uF).
You'll get about 23dB of gain (14x), but you'll have only about 60kOhm of input inpedance.
I suggest you use one triode only, making the triode 1 for the left channel and the 2 for the right one, so you can trade tubes between channels and have a pair of "new" triods.
For that you can use the same values for resistors and cap and get about 20dB gain (12x), but have an input impedance of more than 160kOhm.
Let me know if you need some recalculations or new specification.
Modification of 300B SE AmplifierHide this!Advertise here!
Recommended 300B SE Amplifier Designs gaborbela Tubes / Valves 35 22nd March 2013 02:49 AM
Mono 300B SE Amplifier JPS64 Tubes / Valves 43 22nd May 2011 03:25 PM
FS: Golden Tube Audio SE-300B II Special Edition Valve Amplifier coh-b-pyky Swap Meet 1 24th April 2010 08:31 PM
An intriguing 300B SE-direct-coupled-amplifier Antonio Tucci Tubes / Valves 27 8th February 2006 09:34 AM
For Sale - 300B SE Amplifier ThorstenL Swap Meet 0 26th June 2003 07:37 PM
