Old 28th January 2013, 05:53 PM   #81
tomchr is offline tomchr  Canada
tomchr's Avatar
The three OPTs I've tried have been E-I cores so I can't speak for advantages/disadvantages of other core types. I can't imagine there'd be a big difference between an E-I core and a C core. Between E-I/C cores and a toroid, I would imagine more potential for differences. But that's a guess.
In the end, I would think that the technique used in winding the transformer has far more impact on the sound that the choice of core shape. By technique, I mean the layering of the different windings, interleaving, multiple strands in parallel, etc. But again, that's a guess.
I leave the winding of OPTs to the pros.
~Tom
Modulus-86: 40W/8Ω @ 0.000061% THD. HP-1: 3W/20Ω, 450mW/300Ω @ 0.000032% THD. DG300B and Other Tube Circuits.
Neurochrome : : Audio - www.neurochrome.com - Engineering : : Done : : Right
Old 26th March 2013, 03:24 AM   #82
grufti is offline grufti  United States
grufti's Avatar
Tom, did you ever build a chassis for your Pretty Damn Good 300B Amp?
Old 26th March 2013, 09:05 AM   #83
tomchr's Avatar
Funny you should ask. I just started on the metalwork for the chassis today. I completed the plans over Christmas so this is not exactly a fast process... But I decided to take this week off from work so I could get some headway on this project. The circuit description of the 300B amp is also slowly taking shape on my website.
The amp is still sitting in "DeathTrap" mode in my living room. Playing Dire Straits right now... /me like.
~Tom
Old 28th March 2013, 12:44 AM   #84
tomchr's Avatar
The chassis is coming together. As attached image shows, it's work in progress. But you get the general idea. The chassis measures approx. 11x15 inches. The sides are 3" tall, 1/8" thick architectural aluminum channel, the top plate is 1/8" aluminum sheet, and the front 3/8" extruded aluminum rectangle bar stock. I could probably have used thinner materials, but I like having enough material thickness to be able to cut threads so I went with 1/8" thick aluminum.
The type and position of the feet is not finalized. I would prefer them to be less visible.
~Tom
Old 6th April 2013, 08:43 PM   #85
tomchr's Avatar
Ready for sanding and paint...
Old 6th April 2013, 09:25 PM   #86
SGregory is offline SGregory  United States
I hope you didn't drill those vent hole by hand.
Looks really good. Very Compact and clean.
Living Life Doing the Waltz in 4/4 meter.
Old 6th April 2013, 10:19 PM   #87
grufti's Avatar
That looks more like a CNC job than hand drilling.
It is amazingly compact thanks to the unusually small regulators. Having the heat sink out back will also help things stay cooler than they otherwise would.
This amp will have such a crazy size/weight mismatch. Anybody who lifts it up will surely think that they are lifting a block of steel or lead.
Old 7th April 2013, 01:33 AM   #88
tomchr's Avatar
Thanks! No CNC here. The bottom plate is perforated sheet. The 546 vent holes (per chassis) on the top plate were drilled by hand (using a drill press, obviously). As were all the other holes. I used a stepped drill for the big holes.
For the vent holes, I made a jig from a piece of perf plate and a scrap piece of plywood. The perforated plate was used as a drill template. I held the perf plate, top plate, and plywood together with three brass pins. It worked like a charm and turned out really good.
~Tom
Old 13th May 2013, 07:33 AM   #89
tomchr's Avatar
Default Twins...
This project is finally drawing to a close. I've enjoyed the ride, but am glad to finally see the fruits of my hard work and allow this project to enter "maintenance mode".
I'm really pleased with the results. The sound quality of this amp is quite remarkable. I'm finding new detail in recordings I thought I knew inside and out. But the biggest surprise has been the sound stage. The imaging, width, and depth of the sound stage is unlike anything I've experienced before. I really like it.
I started this project over three years ago and it has spun off two side projects; the 21st Century Maida Regulator and Universal Filament Regulator.
The final amplifier uses three of my circuits:
- 21st Century Maida Regulator for B+ regulation
- 3x Universal Filament Regulator (stacked, 15 mm between boards in the center of the chassis)
- 300B Driver Board
I ended up using JJ 300B tubes and 6N6P drivers. I'm getting about 0.2 % THD (1 kHz, 1 W) and 10 W (3 % THD, 1 kHz). I'll follow up with more measurements at a later date.
Dimensions & weight: Approx. 30 x 40 x 25 cm (W x D x H). 17.3 kg.
For future reference, here are the relevant DIY Audio threads leading up to this design:
RFC: 300B driven by anode follower (6J5/6SN7)
http://www.diyaudio.com/forums/tubes...g-options.html
~Tom
Old 14th May 2013, 12:57 AM   #90
grufti's Avatar
Very nice!
I noticed the three switches next to your input sockets. What are you switching between? Give me about six months and I should have mine finished.
6AV5GAs Re-Visited -OR- Pretty Darn Good SE Amp hareynolds Tubelab 28 7th July 2015 06:58 PM
PGP (Pretty Good Poweramp) syn08 Solid State 263 4th April 2013 07:28 PM
Copyright ©1999-2017 diyAudio
