KR Audio Marconi R valve amp?
Old 18th August 2012, 10:05 PM   #1
kenneth is offline kenneth  Sweden
Question KR Audio Marconi R valve amp?
Has anyone any suggestions (schematics) on how to build a amp with my newly bought KR Audio Marconi "R" valves. I have a pair of single ended output trans (primary 5kohm). I would prefer something without interstage transformers as i would like to keep the cost down. R valves specifications: Max plate voltage 180v, Max current 2ma(vf:4v,vg:0v), Va 120v, Ia 1ma, Vg -0.5v, Transdoctance 0,3ma/v.
Thanks,
Kenneth
Old 19th August 2012, 01:35 AM   #2
kevinkr's Avatar
These might be applicable in a simple line stage with an additional stage for buffering but they have insufficient transconductance, mu, and current handling for practical use in a two stage power amplifier.
"To argue with a person who has renounced the use of reason is like administering medicine to the dead." - Thomas Paine
Old 19th August 2012, 08:46 AM   #3
I bought these tubes mainly for display use, but it would be interesting to build a amp with them. A linestage using these tubes would also be fine. I am aware of the limitations of these tubes and dont expect hifi sound from them. I have ECC81,82,83,85, 5687, 6922, 6072a, 6sn7 tubes maybe suitable for a linestage with the Marconi tubes?
Thanks!
KR Audio Marconi R valve amp?Hide this!Advertise here!
Convert a non-valve amp to a Valve (tube) Amp seanthomas46 Instruments and Amps 17 20th April 2015 05:11 AM
Marconi 2005 jartiili Equipment & Tools 4 10th November 2013 10:38 PM
KR AUDIO 842 VHD DHT Matched Pair High Power Single Ended Tube Amplifier ppereira Swap Meet 0 21st November 2011 08:29 PM
Kenwood KR-5340 amp Woody Rod Solid State 3 21st August 2011 06:14 PM
Marconi TF2005R reddish75 Equipment & Tools 3 6th January 2011 11:15 AM
