Distortion
Distortion
Old 18th August 2012, 08:29 PM   #1
Hojvaelde is offline Hojvaelde  Denmark
Default Distortion
Hello
I would like to measure the distortion of my amp.
I have sent with a drawing of my thinking method.
The used opamp is with very low distortion.
But how should I interpret that I get out of the differential amplifier.
Benny
Old 18th August 2012, 09:15 PM   #2
Nelson Pass is offline Nelson Pass  United States
The one and only
Nelson Pass's Avatar
Distortion
If the circuit is set up and adjusted correctly, you would see the difference
between the input and the output of the tube amp. After you null out
amplitude and phase, you would be left with distortion and noise.
Old 18th August 2012, 10:28 PM   #3
tomchr is offline tomchr  Canada
tomchr's Avatar
If your goal is to measure the distortion of your amp, I'd suggest getting a quality external USB or FireWire sound card and some software (TrueRTA comes to mind, though, there are others).
Or... Get your paws on an HP 8903A or 8903B audio analyzer.
However, if your goal is to build a distortion analyzer, I'd get the service manual for the HP8903A and build a similar circuit. Or build the circuit in your schematic. I think your system will be limited by the accuracy of the phase adjustment, though. Recall that the phase of your amp varies with frequency so the phase of the compensation amp will have to vary accordingly.
~Tom
Modulus-686: 240W/8Ω @ <0.00025% THD. Modulus-86: 40W/8Ω @ 0.000054% THD. DG300B & Other Tube Circuits.
Neurochrome : : Audio - www.neurochrome.com - Engineering : : Done : : Right
DistortionHide this!Advertise here!
How Distortion Free are the Distortion Measurers? fas42 Equipment & Tools 108 10th May 2014 12:52 PM
How to know distortion? Frosteh Multi-Way 13 15th April 2012 07:38 PM
Non Distortion? johngalt47 Solid State 5 8th July 2010 09:57 PM
Non Linear Distortion testing - Harmonic Distortion JMB Multi-Way 0 20th July 2004 02:54 PM
The look of distortion. Joel Tubes / Valves 3 26th June 2003 10:51 PM
