Dropout in RTP3 phono stage
Old 18th August 2012, 08:42 PM   #1
Alex M is offline Alex M  Europe
Default Dropout in RTP3 phono stage
My DIY version of Allen Wright's RTP3C has been showing some odd behaviour. From time to time, the right-hand channel of the phono stage becomes very faint. There is no crackling, popping or other noise - just sometimes all I can hear is the left channel.
I have swapped the single 6922 valve over for a spare one, with no improvement. Swapping the signal polarity at the source select doesn't make a difference; I have reformed almost all the soldered connections, and I have checked the continuity of the tonearm cable.
The phono stage is the left-hand portion of the schematic here: RTP3C circuit. It's such a simple circuit that I would have thought it would be easy to find a fault...
I hate intermittent faults! Has anyone else come across this kind of problem?
Thanks,
Alex
Old 20th May 2013, 07:43 PM   #2
Nelson Bass is offline Nelson Bass  Denmark
Banned
Hi Alex,
Did you find the root cause?
Old 20th May 2013, 10:35 PM   #3
Hi Nelson,
As it happens, I posted an update to a different thread, since I had no responses to this one!
It turned out to be due to a partial failure of the shunt regulator for that channel, which resulted in a droop of the HT down to 260V after an hour or so. The current sink on the emitters of the input transistors means that a constant 240V is dropped across each 25K cathode resistor, so the HT voltage sag is enough to starve the input stage of voltage - hence the signal dropout.
As I mentioned in the other thread, I replaced the HPHV regulator with the much simpler Salas HPHV regulator, which is still working fine.
Alex
Old 22nd May 2013, 05:59 AM   #4
Banned
Great! Thx for your reply. :-)
Dropout in RTP3 phono stageHide this!Advertise here!
Adding a 3rd gain stage to an MM phono stage, to make it suitable for LOMC? andyr Analogue Source 10 16th August 2012 05:10 AM
12az7a phono stage-12ay7a line stage tubenut33 Analog Line Level 1 23rd July 2011 11:44 PM
DIY phono to replace roksan phono stage seroxatmad Analog Line Level 6 14th December 2008 06:46 PM
new phono stage or old preamp with phono? flohmann Analog Line Level 2 2nd October 2008 10:51 PM
Should I replace Scott 222C phono stage with Claret phono stage? Bing Yang Analogue Source 0 22nd August 2005 07:41 AM
