300b all-DHT SET
300b all-DHT SET
Old 18th August 2012, 07:31 PM   #1
andyjevans is offline andyjevans  United Kingdom
Default 300b all-DHT SET
I've been using nothing but DHTs as input tubes for about 3 years now, and my 300b amp has gone through various configurations using mostly 46, 10Y and 26 tubes in the input. I've gone through various topologies also. The worst by far was resistor loads in anode and cathode with cathode bypasses. Battery grid bias was an improvement, but I got best results with filament bias. My attempts at direct coupling the first stages ran into issues with cathode resistors and bypasses, and I gradually lost interest and started preferring all-DHT 2a3 PP amps as an alternative.
When I started using the 4P1L my interest in the 300b SET revived. Here was a tube that worked exceptionally well in filament bias. As a triode it's mu was around 10 and it's anode resistance around 2k. Perfect! And the filaments were around 2v at 650mA, so quite easy to provide a DC filament supply for. They sound best at around 15mA or more, and I had some interstages I could try out so I rigged up an experimental amp. After starting with a 26 input stage I went over to two similar stages of 4P1L. This seemed to give the best tone to the instrumental sound - the 300b is on the warmer side and the 4P1L on the leaner side. The 4P1L had better treble than the 26 also. It is a little microphonic in the input stage but not grossly so, and it doesn't hum.
Having decided to use two similar stages with filament bias, I then started to play around with interstages. I like the 126C from Hammond in the driver stage at present - it is a rounder and fuller sound. In the input I like the LL1660/18mA which is a leaner sound with better treble detail. The combination seems to have good tone. I tried using LL1692A into LL1660/18mA but strangely this sounded too lean and I lost a bit of the magic. The LL1660 is better to my ears than the LL1692A, but not by much. It has better low level and treble detail at the expense of a slight loss of smoothness.
So I ended up with a very satisfying sounding 300b SET. I enclose a draft schematic to kick off some discussion. The voltages are approximate and need refining - I'm still at the tweaking stage. This has become my daily listening amp and gives me a lot of pleasure. It's transparent and detailed as you'd expect from DHTs and has particularly good tone and low level detail with orchestral instruments - you can clearly hear the individual tone quality of clarinets, bassoons, oboes and so on, and percussion in jazz groups is excellent - resonant thwack to the drum skins and a nice crisp metallic sound to the cymbals.
I owe a huge debt of gratitude to Thomas Mayer, Rod Coleman, Ale Moglia and Paul Leclercq for helping with this project, and to all members of the London Audiocircle for general support over the years.
Andy
Old 20th August 2012, 05:15 PM   #2
radiostar is offline radiostar  Yugoslavia
Nice project!!!
I need to add one stage to my 300B 10Y DHT SE Amp, but here is hard to find 4P1L ...
Thanks for idea Andy!
tubes.rs
Old 20th August 2012, 05:23 PM   #3
kevinkr's Avatar
300b all-DHT SET
Very cool Andy.. How about a couple of pictures of your amplifier?
"To argue with a person who has renounced the use of reason is like administering medicine to the dead." - Thomas Paine
Old 21st August 2012, 03:38 AM   #4
tcqanh is offline tcqanh
Quality of Ka bypass capacitor is concerned to sound quality much, the worst is electric, then bipolar. the higher value of this C, the worse sound of high frequencies.
I think if you use film or MKP capacitor for this situation then you may have a different feeling.
I you performe fixed bias for all circuit, so you don't need any more Ka capacitor. The sound you get maybe so good.
Old 21st August 2012, 04:07 AM   #5
did anyone use Gold Lion 300B ? How is its sound character when compared to the others ?
Old 21st August 2012, 10:26 AM   #6
gmant123 is offline gmant123  Argentina
gmant123's Avatar
300b all-DHT SET
Default Beautiful!!!
Hi Andy:
Congratulations!!!
Any reason not to use fixed bias in the 300b tube?
Alberto.
Analog as the sound of the nature....
Old 21st August 2012, 12:34 PM   #7
To answer the question of cathode bypass and fixed bias on 300b.
I tried all kinds of cathode bypasses - polypropylenes, electrolytics (awful), sandwiches with teflon bypasses etc etc. I used some clip leads and went through all my stock in various combinations. Everything put a veil over the sound, so I just gave up.
Tried fixed bias on the 300b and it did improve the bass, but I couldn't get a certain hardness out of the treble - tried polypropylene last cap in the DC supply, various voltage regs etc. Didn't try choke input. Didn't try more sophisticated shunt regs. I was getting variations in sound so it did seem this could be optimised, but I left it alone for the time being. You're right to suggest it.
In terms of topology, you could do this in various combinations of boxes since the stages are transformer coupled. Presently I have the first stage as a preamp, and 2 stages in the amp. I also considered 2 stages in the preamp and one stage in the amp - this would allow me to put the power supply in the amp with the output stage. Right now I have a separate power supply. I also have a separate filament supply for the input stage because it has choke input, and I want to keep the filament chokes away from the signal. They do have a field around them. This was crucial when I used the 26 in the first stage, but seems the 4P1L is less prone to hum. I run the 300b off DC, but this could be run off AC as well.
In terms of filament bias, there are a small number of DHTs that can be used without the DC supply getting ridiculous. 26 is easy and can be run off a 12v DC supply even. 01A is OK. 4P1L is good. Basically you want low filament voltage and current for the tube, plus a low voltage bias point. 10Y is not impossible since the bias voltage is lower than most, but you have to add on 7.5v for the filaments, and the filament current means big transformers. Sounds good in filament bias as Thomas has proved. I used to use that but found the 4P1L much easier to use, and also it sounds extremely good. More gain and lower plate resistance too. Where it gets a bit out of hand is 46, which is a great tube otherwise. At the recommended operating point of -33v you'd need a filament supply of at least 40v at 2.5 amps. The cathode resistor would be 13.5 ohms with 82 watts through it - would need a 200 watt part at least! With the 4P1L the filament supplies are quite sensible - 650mA and anything up to around 24vDC. Cathode resistor should be OK at 20W. These resistors get hot and should be 2 or 3 times the rating.
I'll see if I can put together some pics.
Old 22nd August 2012, 02:21 AM   #8
Bigun is offline Bigun  Canada
Bigun's Avatar
300b all-DHT SET
Nice design, it certainly appeals to me with all those DHTs. And Sakuma-san would be proud to see your work. I'm looking forward to some photos.
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig.
Old 22nd August 2012, 06:58 AM   #9
vega65 is offline vega65  Norway
300b all-DHT SET
Nice !
unbypassed cathode resistors in the 4p1l stages ?
The gain in first and second stage ?
max voltage swing of driver stage ?
Best regards vegard
Old 22nd August 2012, 08:37 AM   #10
revintage is offline revintage
Do a simple mathematic exercise and find the local feedback introduced by the 20/25ohm resistor against the reactance of the ITīs.
300b all-DHT SETHide this!Advertise here!
High end Ortho Amp on a basic Russian Tube DHT SET DIY design regal Headphone Systems 2 7th December 2012 12:46 PM
300B (or other DHT) biasing options tomchr Tubes / Valves 20 2nd April 2012 01:03 PM
FS: Two monoblok PP 2a3/300b all-DHT amps, UK andyjevans Swap Meet 3 9th March 2012 09:01 PM
Help on designing full DHT SET power amplifier milen007 Tubes / Valves 56 11th August 2011 10:38 PM
DHT for 300B problem neskor Tubes / Valves 6 13th May 2011 10:09 PM
