The end of tubes?
The end of tubes?
Old 6th June 2018, 12:40 AM   #41
bluerooster is offline bluerooster
Originally Posted by Bigun View Post
I collect valves here and there as the opportunity arrises and have the one shown attached, a tetrode not a triode. As it needs a 100 Amp heater I don't expect to be using it soon.
An old "pole pig" will feed it nicely. Now finding a suitable input choke would be another animal.
Old 6th June 2018, 02:37 AM   #42
gabdx is offline gabdx  Canada
It is simple but costly V1505 at 2.5kv its alright. Just cannot find the tube anymore.
Otherwise you will have to resort to // a few tubes for a so so result.
amplificateurslegrand.ca
Old 6th June 2018, 02:38 AM   #43
JMFahey is offline JMFahey  Argentina
JMFahey's Avatar
Originally Posted by bluerooster View Post
An SS kilowatt amplifier is way complicated, while a kilowatt tube amp is quite simple.
You-must-be-joking
This is a 1000W tube amplifier.
It is way larger than it looks in a picture, those are not KT88 or similar but 813, now scale your mental image up by 3X or 4X
Dont worry, supply "only" runs at 2500V DC .... just what the Doctor ordered for a homemade:
Design/make/service musical stuff in Buenos Aires, Argentina, since 1969.
Old 6th June 2018, 03:51 AM   #44
nice parallel push pull.
the 813 is a toy compared to the V1505
Old 14th June 2018, 04:17 PM   #45
Traian B is offline Traian B  Romania
http://www.cpii.com/docs/datasheets/78/8974.pdf
The end of tubes?Hide this!Advertise here!
FS: Various tubes and high end tuners sachi Swap Meet 0 23rd July 2011 07:25 AM
Cleo: End to End 24bit 192khz USB DAC with tube output bcherry DIY HiFi Supply 7 3rd July 2010 11:15 PM
Single-end Power amp with tubes Progg70 Tubes / Valves 3 4th April 2008 02:32 PM
high end version of low end phono stage dsavitsk Solid State 20 1st September 2005 11:51 PM
