Behringer DEQ2496 for testing amplifiers and preamps frequency response ???
Old 15th August 2012, 12:30 AM   #1
HP8903B is offline HP8903B
Default Behringer DEQ2496 for testing amplifiers and preamps frequency response ???
Does anyone know whether the Behringer DEQ2496 would be good to measure frequency response of tube amps and preamps ?
Does it have a pink noise generator ?
How would I hook up the amp's and preamp's output to the DEQ2496 ?
Old 15th August 2012, 01:56 AM   #2
Pano is offline Pano  United States
Pano's Avatar
Well, it would work but probably isn't the best tool. Yes, it has pink noise.
You could route the amp or preamp back into the analog inputs via XLR connectors. Keep the level low enough not to clip (the DEQ can take a high level in).
Be sure to load your amp or preamp as it normally would be.
Take the Speaker Voltage Test!
Old 15th August 2012, 02:34 AM   #3
Thank you
Which other tools would be best ?
Old 15th August 2012, 03:10 AM   #4
Pano's Avatar
A sound card and some software would be best, but if you already have the DEQ - why not?
I made up a pair of banana to XLR that I've used to go from tube amp into the DEQ, the DCX and an M-Audio soundcard. Works just fine. Use pin 2 of the XLR as positive, pin 3 neg. You can tie pin 1 to amp ground or just leave it open at the banana end. Do whichever gives you the lowest noise.
Set your DEQ to pink noise and 96Khz sample rate and off you go!
Old 15th August 2012, 04:58 AM   #5
What would you recommend to measure distortion ?
Basically I want to be able to measure the performance (frequency response, distortion) and power output.
Behringer DEQ2496 for testing amplifiers and preamps frequency response ???Hide this!Advertise here!
Integrating the Behringer DEQ2496 AstralFurious Digital Line Level 1 19th December 2011 09:11 AM
Behringer DEQ2496 Schematic Claus Digital Line Level 12 10th July 2011 01:40 AM
BEHRINGER EP1500 frequency response Mambo Instruments and Amps 1 2nd September 2009 09:50 AM
FS:Behringer DEQ2496 Ryssen Swap Meet 15 16th April 2009 08:24 PM
Behringer DEQ2496 into T Amp? joesan Digital Source 7 19th October 2005 10:30 AM
