I need datasheet of 8753 tube, help me! - diyAudio
Old 14th August 2012, 06:34 PM   #1
Default I need datasheet of 8753 tube, help me!
I need datasheet of tube 8753 (Amperex). If anyone knows, please help me. Is it can use for Audio?
Thanks a lot.
Old 14th August 2012, 06:50 PM   #2
7N7 is offline 7N7  United Kingdom
7N7's Avatar
Thanks a lot.
It would be helpful if there is a European number - and a picture of the valve would help.
7N7
Plug them in and light them up
Old 15th August 2012, 03:29 AM   #3
My cross reference list show the 8753 as the same as CV1019.
And looking for data on the CV1019 at Duncans Webpages says its the same as a PM2.
If all that is correct then the the 8753 is the same as a PM2 which was intended to be an audio output tube.
http://www.andycowley.com/valves/old...G/RVG-p011.pdf
Does that look like what you have?
Ian
Old 15th August 2012, 05:00 AM   #4
Thanks 7N7 and Ian for your support.
I send pictures of 8753 tube; please help me get datasheet of this tube. The 8753 Ampererex tube has 9 pins not 4 pins as PM2.
@7N7: I don't know European number of 8753 tube.
Old 15th August 2012, 05:08 AM   #5
HollowState's Avatar
I think not. There are some 8753's offered on ePay. Amperex made some special types for use as RF outputs in mobile equipment and I suspect that's what these are. The high number suggests late production. I looked in all my info and can't find it.
1944: 18 year olds storm the beach of Normandy into almost certain death.
2017: 18 year olds need a safe place because words hurt their feelings.
Old 15th August 2012, 05:11 AM   #6
TonyTecson's Avatar
beam deflection tube? calling on smoking-amp......
planet10 needs your help: Let's help Ruth and Dave...http://www.diyaudio.com/forums/plane...ml#post5010547[B
Old 15th August 2012, 10:05 AM   #7
7N7's Avatar
Looks a bit like a YL1130, without of course the gold pins. But I think that YL1130 is 8408. There was I think an indirectly-heated version of YL1130 (6.3v heater) Could that be it?
As Amperex was part of Philips, many of the types were European designs e.g. 6688, 7721, 7788; step forward Amperex experts!
I'm amazed that such a recent type should be unknown; one imagines that there should be an industry association list.
Naive? Ah well!
7N7
Old 15th August 2012, 11:12 AM   #8
DF96 is offline DF96  England
Is it a single-ended dual tetrode? How big is it? 9 pins could be B9A miniature or B9D beefy output valve. Difficult to tell from the photo, but the envelope shape looks more like B9D to me.
Old 15th August 2012, 02:01 PM   #9
Location: Near Eindhoven, the sanctum of the pentode. and among that other things.
Send a message via Skype™ to v4lve lover
i think its in the same series as the YL1190
Dual anode dual G1 tetrodes for mobile use, whit a very special 0,5 second warm up time B9d base..
v4lve
Old 15th August 2012, 02:06 PM   #10
try measuring the resistance between pins 4 and 5 this might tell us something.
valve.
3C30 tube...datasheet...help !!! aldovan Tubes / Valves 1 17th March 2012 11:50 PM
Searching for a TUBE datasheet GE GL-421 tablekwan Tubes / Valves 1 3rd March 2011 11:27 AM
max plate voltage rating in tube datasheet jarthel Tubes / Valves 11 25th October 2006 04:24 PM
Datasheet of PTT4 tube? reaction Tubes / Valves 0 25th May 2006 10:27 AM
Help translating russian tube datasheet Simpleton Tubes / Valves 7 15th June 2005 01:02 PM
Copyright 1999-2017 diyAudio
