New 6L6GC Project. DC -> LTP - Page 7 - diyAudio
Old 5th December 2012, 06:02 AM   #61
freax's Avatar
a thing of beauty, well done!!!!
I see you are using coax for the run from the rear rca sockets to the front volume control, ever considered using a thicker gauge copper core coax?
The center conductor looks a little on the thin side, rg-59?
Not that it matters much.
It just seems to be a bit of a waste to have so much copper bus running around and then use cheap grade coax for the run to the front volume control.
diyaudio is against your rights. I do not have the right to be forgotten and after asking the issue has been ignored, therefore I'm leaving (peacefully) for this reason. I stand up for my rights. So long and thanks for all the Fish
Old 5th December 2012, 06:08 AM   #62
sorenj07's Avatar
thanks very much! basically that coax was what i had on hand, i think it was from an old oscilloscope probe lead, so i figured it had to be well shielded. probably overkill. the conductors are indeed tiny but i can't imagine it would make a difference at the tiny signal current at the input..?
Old 5th December 2012, 06:15 AM   #63
freax's Avatar
Originally Posted by sorenj07 View Post
thanks very much! the conductors are indeed tiny but i can't imagine it would make a difference at the tiny signal current at the input..?
I wouldn't spend too much on getting some proper coax, but I work on the idea that if something makes a difference and I assume that it won't but it does then I have lost out on an opportunity to improve the sound quality, and for the cost of a few dollars worth of coax, thats a small price to pay for my peace of mind.
Nobody here I think will tell you that by going to a larger copper conductor will make a difference, its a personal preference of mine as I am moving all of my rca connections over to BNC and RG-6 Quad shield coax (not copper coated steel, pure copper.) which has an 18 AWG center conductor.
By removing one last slim remote possiblity of there being a change or reduction on the sound quality by going to BNC and RG-6 Quad for a few dollars I am ensuring that the signal gets the best possible chance to make it into that tube and be amplified.
I'm not the type of person to go out and buy $50,000 dollar cables, RG-6 Quad pure copper core is where I draw the line and I cut and crimp my own BNC RG-6 cables.
If I can prevent $50 from going to corrupt cable companies by promoting the use of home-made BNC and RG-6 quad then my work is done, $50 could get you 100 metres of rg-6 and 6 or more bnc rg-6 connectors.
But then again as you said its what you had laying around.
Old 14th January 2013, 12:02 AM   #64
sorenj07's Avatar
One of the Chinese 6L6GCR's blew. Now I've got a quad of JJ/Tesla 6L6GC's singing along and all is well. Still contemplating some global feedback but things are sounding pretty Ok without.
final schematic, using 1.5a slow blow fuses
Old 14th January 2013, 02:05 AM   #65
AJT is offline AJT  Philippines
AJT's Avatar
i guess 460v is too much for a chinese 6l6gc, you can try the chinese El34 with that voltage...
the best advertisement for a good audio design is the number of diy'ers wanting to build it after all the years....never the say so of so called gurus....
Old 15th January 2017, 09:51 PM   #66
sorenj07's Avatar
happy to say this one is still trucking along after 4 years.
Old 15th January 2017, 10:25 PM   #67
BinaryMike's Avatar
Good to know. Did you ever collect any performance measurements on this project?
Old 15th January 2017, 10:26 PM   #68
Be careful of the phase of the output transformer. Otherwise you will have positive feedback to the cathodes, instead of negative feedback.
The ratio of 1/2 primary (1650 Ohms) to 4 Ohms of winding is about 20, which will feedback about about 5% of the 1/2 primary voltage.
Suppose the basic Ultra Linear gain stage is about 10, with the cathode feedback that would be 50%; that could be perhaps about 6 dB negative feedback.
(I think I got that calculation right).
Old 15th January 2017, 10:31 PM   #69
sorenj07's Avatar
unfortunately not.. if i had a scope handy i'd have taken a look. but beyond getting a circuit together that a majority on the forums approve of, i'm happy to sit back and listen to some music.
thanks for the calculation! i'm pretty sure i got it right, after all, with those Edcors everything is clearly labelled and color coded.
DC Imbalance with the LTP rlaury Tubes / Valves 15 30th May 2011 10:03 PM
12V -> 170V DC/DC smps, what's wrong? markusA Power Supplies 5 28th March 2011 10:02 PM
DC coupling on a LTP? Opinions and help needed on Fred's design. Brit01 Tubes / Valves 6 25th October 2010 11:59 AM
DC-DC buck regulator layout -> what's your opinion? Danko Power Supplies 14 31st December 2005 04:31 PM
Copyright 1999-2017 diyAudio
