#51 |
Ok, this simplifies things a bit. I didn't know you don't have to subtract the voltage drop as a result of the plate resistor! This makes it a lot easier, and I'll probably re-draw the schematic keeping the original 460V supply. I don't want to risk arc-over on the noval tube socket just for superfluous headroom..
#52 | |
#53 | |
Keep in mind the tube curves show voltage respective to cathode. It does often say, eg. on the X axis, Plate Voltage - in fact it's Cathode to Plate voltage. Same thing with grid voltage, it's actually Cathode to Grid voltage. The basic construction of a load line assumes a common cathode connection, i.e. cathode is grounded, which is why we use said curves that imply cathode = 0V = ground.FOr that scenario, the maximum current through the circuit would be if there was 0V Vkp, which is why we put B+ divided by plate resistor as one point the load line goes through, on the Y axis. The maximum voltage in the circuit is the actual B+ which is why we use this as a second point the load line goes through, on the X axis. Here you might notice that in a realistic circuit, there is a cathode resistor used to develop bias voltage, but because this is fairly small with respect to B+ is, we tend to disregard that the cathode is not a 0V when drawing the load line, unless we are designing for something like a low voltage tube. However, in order to get a LTP to work well, either we need to have a common cathode resistor with a rather high voltage drop, or a CCS which also uses a minimum of voltage to even work. With a CCS, there is an extra feature, that the cathodes will follow what you do on the grids in trying toi keep the current constant (which is what a CCS does). Because you are connecting your LTP directly to the plate of the previous stage, the grids will be at the same voltage as the plate of the previous stage. This means the cathodes will be a few V higher, and in this case these voltages are not at all small with respect to B+ so you MUST take them into account. So, in this case, you can't use B+ on the X axis of the tube curves for the LTP, but the actual maximum Vkp, which is for all intents and purposes B+ less Vp of the first stage. |
#54 | |
From the looks of things, especially on Pete Millett's page,
Current Source the 10M45 isn't unhappy at 5mA, so I think to keep things simple (and the parts list shorter) I'll just use those, since I have 4 already. 600 ohms should provide the 5mA current, yes? Quote:
#55 |
#56 |
Looks good... protection diode between grid and cathode of top 6N1P, anode to grid, cathode to cathode. 1N4148 will do but you might want to look up something a bit more sophisticated, maybe BAS21 or something like this, as you want low capacitance.
I would also recomend a bleeder resistor between 463V supply and ground, just in case. Also, grid stoppers (1k for now) on 6L6GC. These may need to be made a bit higher, depending on how the amp will clipping (blocking distortion due to attempting to drive the grids of the 6L6 positive). Finally, check your swing considering that you have 47k plate resistors for the 6N1P and 100k grid leaks for the 6L6, the swing will be determined by a dynamic load line through your operating point on the 47k lstatic load line, but for 47k in parallel with 100k, roughly 31k or so, which is signifficantly smaller than the 47k plate resistor. |
#57 | |||
http://www.nxp.com/documents/data_sh...148_1N4448.pdf When you say "cathode to cathode", what does that mean? I get that the grid is always supposed to stay negative with respect to the cathode, and anode should always be positive with respect to the grid and cathode, but the last part stumped me.. Quote:
Thanks so much for all the help so far. Can't wait to get this project up and running, and post some in-progress build pictures
#58 | |||
Diode anode to tube grid diode cathode to tube cathode This will make the diode cinduct whenever the grid of the triode goes about 0.5V positive WRT cathode of the tube. In all normal conditions the diode will be reverse-biassed and will not conduct. The problem with the capacitance is that it varies with the reverse voltage on the diode junction. Check that it is small at around -2V or so, if yes - 1N4148 will do. Don't have the diode data at hand so I'm leaving this to you ![]() Quote:
#59 | |
Sounds good! I'm polishing some transformer bells now. |
#60 |
got 'er built. all is well except those 72K plate resistors on the 6N1P are dropping way too much voltage, I'm reading like 180V on the anode. looks like it's back to 47K as planned. that said, it doesn't distort audibly and there isn't any audible hum, so i'm happy so far
![]() overall wiring ![]() bias supply ![]() outside ![]() inevitable glow shot
| DC Imbalance with the LTP | rlaury | Tubes / Valves | 15 | 30th May 2011 09:03 PM |
| 12V -> 170V DC/DC smps, what's wrong? | markusA | Power Supplies | 5 | 28th March 2011 09:02 PM |
| DC coupling on a LTP? Opinions and help needed on Fred's design. | Brit01 | Tubes / Valves | 6 | 25th October 2010 10:59 AM |
| DC-DC buck regulator layout -> what's your opinion? | Danko | Power Supplies | 14 | 31st December 2005 03:31 PM |
