#31 | |
#32 |
think i will try a 20k resistor on the -ve leg of this 12.5vdc heater supply to the amp star ground and see what happens. did not think of biasing up to the HT line (via voltage divider of course) because this is still 12vdc biasing on another dc HT voltage of a totally different transfo.
#33 |
Thanks, all. Just been peering into my amps for the first time in years.
When I made them, some years ago, I agonised for some time over heater grounding. Small valve heater supply is current source, and heaters are in series. Eventually I decided to ground the middle of the chain, probably on the basis that any fluctuation in current would cause least common mode voltage variation. Actually current is as constant as I've ever seen a constant thing be. When I get round to it, I'll ground the negative end of the chain, so the valves with greatest gain are least positive, and the elevated drivers will see 20-odd volts. I guess the ultimate would be to connect the centre of the chain to an elevated ground, but I don't care enough. The amps have been happy for years as they are. Heaters are left at half power when not in use, so they've been on for years. There is no apparent difference in the condition of the valves with negative heaters. I've been a bit lazy about bias I notice... |
#34 |
While I am still on a pretty steep learing curve about all this it occurs to me that some confusion may come from the way this technique is
explained, as I recall I read that referencing a DC voltage allowed the AC componet to "Float" on top of the DC stablizing the leakage current from heater to cathode...or something close to that. I do know it helped to reduce hum in my 12au7 preamp. |
#35 |
yes, that's the thing....
http://www.elab.ph/forum/index.php?topic=32688.0 |
| Coleman filament supplies for 300b tubes | renton1 | Swap Meet | 1 | 2nd January 2012 04:10 PM |
| Tentlab Filament Supplies on Ebay and Black Gate caps wanted | Carrier Bag Man | Swap Meet | 2 | 5th April 2011 02:31 PM |
| FS: Tentlabs DHT Filament Supplies | damohpi | Swap Meet | 0 | 14th April 2010 10:53 AM |
| Alpine MRV-1507 - RCA Ground Floated - Need help | silversweden | Car Audio | 41 | 5th June 2008 06:20 PM |
| Tentlabs DHT Filament Supplies | damohpi | Swap Meet | 1 | 12th March 2008 05:27 AM |
