Please educate me: Tube testing, the life test, and Grid Leakage
Old 15th October 2012, 10:04 PM   #21
Uunderhill is offline Uunderhill  Canada
Originally Posted by DF96 View Post
gm and plate resistance are related: Rp = mu / gm
Measure any two of these and you can calculate the third. You could measure Rp by varying Rs in your circuit and seeing how gain varies.
Then, knowing Rp, you can calculate gm from your results.
Seeing this response was a good moment. I think it puts many things together.
for a tube - the small signal parameters are as follows
........................ mu = gm x rp
where, mu is the maximum theoretical gain for a particular tube.
and rp is the plate resistance
for the common cathode amp above, Rp is connected in the circuit, so substitute Av for mu - without a load, the gain is as follows.
........................ Av = gm x rp//Rp
However, a switch could be connected in series with a load resistor - Rs.
Measurements, could be taken - switching the load resistor in and out.
so with a load resistor
....................... Av = gm x rp//Rp//Rs
Old 16th October 2012, 10:20 AM   #22
DF96 is offline DF96  England
Yes.
Please educate me: Tube testing, the life test, and Grid LeakageHide this!Advertise here!
Testing with test-records of RIAA amp. Helmuth Analogue Source 5 14th July 2011 08:52 PM
Mullard 12AU7 tests bad when running grid leakage test? sbelyo Tubes / Valves 6 10th April 2011 09:13 PM
SMPS gate drive - please educate me Th3 uN1Qu3 Power Supplies 5 16th July 2010 04:48 PM
Amplifiers, AB comparative testing, a blind test method. destroyer X Solid State 34 29th September 2009 12:39 PM
Testing for cap leakage taj Parts 15 7th October 2007 08:31 AM
Copyright ©1999-2017 diyAudio
