EF86 + 4*EL84PSE
EF86 + 4*EL84PSE
Old 9th August 2012, 06:56 PM   #1
hkoetz is offline hkoetz  Netherlands
hkoetz's Avatar
Default EF86 + 4*EL84PSE
Can I use an EF86 in pethode mode to drive 4 EL84 PSE. I think I need the penthode gain, as I plan to use cathode feedback from the OPT secondary.
Lateral is best!
Old 9th August 2012, 07:31 PM   #2
DF96 is offline DF96  England
You have not given anywhere near enough information for your question to be answered. Show us your draft circuit, and expected signal levels etc.
Old 10th August 2012, 12:31 AM   #3
aardvarkash10 is offline aardvarkash10  New Zealand
aardvarkash10's Avatar
short answer is "possibly"
Obvious question is "why feedback from the OPT when you have all the elements in place for a Schade setup?"
"It may not be easy for some to not hear differences, even if they are not there." - Vacuphile,
Old 10th August 2012, 06:20 AM   #4
revintage is offline revintage
EF86 is a not a very good candidate as Schade driver. More Gm and current is a must. A depletion MOSFET will also work better than most pentodes. But the basic Schade idea is good.
Cathode feedback might work with a triodestrapped EF86, triodestrapped EL84s and something like a 1.3k:8ohm OPT as the feedback will be very, very low.
But as DF96 says more data is needed.
Old 10th August 2012, 06:37 AM   #5
artosalo is offline artosalo  Finland
artosalo's Avatar
Originally Posted by hkoetz View Post
...I plan to use cathode feedback from the OPT secondary.
Does this mean that the OPT secondary will be connected between the cathodes of the output tubes and ground ?
Or do you plan to feed the voltage from the secondary to the cathode of EF86 ?
Old 10th August 2012, 07:13 AM   #6
About typical cathodefeedback (to the output tubes cathodes) it will introduce some DC over the speaker. Will typically be 20-50mV with 160mA Ia.
Didnīt see that one.
Old 10th August 2012, 04:42 PM   #7
hkoetz's Avatar
I was thinking in terms of output impedance of the EF86 in penthode mode, which is, depending on the anode resistor 100 - 200k. 4 EL84 PSE with 1 M grid resistor each, may present to low input impedance.
What would be a Schade set-up?
Yes
Thank you all for your reactions sofar.
Lateral is best!
Old 10th August 2012, 04:57 PM   #8
jane is offline jane  Norway
jane's Avatar
Who is talking about Schade feedback?
He mensions cathode feedback, and EL84 is a good candidate for this kind of feedback (especially in triode mode).
Life is hard - Then you die.
Old 10th August 2012, 07:05 PM   #9
Pentodes are used to working into a lower impedance than their own anode impedance; unlike triodes they don't need a high impedance load for linearity. However, there is a potential problem of Miller capacitance. The EL84 has low feedback capacitance itself, but the base and wiring will add a little and then you multiply by 4 and the output stage voltage gain. You could find that it works fine at LF but loses gain at HF. You need to estimate the capacitance which the EF86 anode will see.
The so-called Schade connection involves turning the output stage into an anode follower (analogous to an op-amp inverting configuration). This will reduce the effect of capacitance so may be worth exploring.
EF86 + 4*EL84PSEHide this!Advertise here!
EF86 trancy Tubes / Valves 51 16th February 2015 09:37 AM
el84pse schem, need advice oliezt_sayfu Tubes / Valves 11 13th May 2011 10:11 AM
EL84 + EF86 takashi Tubes / Valves 10 28th March 2008 02:30 PM
EF86 Gm dsavitsk Tubes / Valves 7 31st March 2007 07:59 PM
EF86 penthode specter73 Tubes / Valves 8 7th December 2005 05:38 PM
