Power Transformer Help
Old 8th August 2012, 03:38 PM   #1
oldschooltube is offline oldschooltube  United States
oldschooltube's Avatar
Default Power Transformer Help
I am looking to upgrade the power transformer in my S-5 Electronics K16ls kit amp but I have done away with the ss rectifier and replaced it with 2 paralled 6BY5GA tubes. The amp uses 8x 6005 tubes in ppp and 2x 5670 tubes. The info I got from S-5 about the stock power transformer is 120v primary, 180v secondary (actually measures around 200VAC) @ 250mA, 6v secondary @ 5.5A. I would like to find a power transformer that has slightly higher HV to account for the voltage drop across the rectifier tubes but I have had no luck finding something that will supply 225-230V @ 250-300mA. I don't want to go any higher on the HV and cook the 6005s. Any ideas would be greatly appreciated.
Old 8th August 2012, 04:28 PM   #2
kevinkr's Avatar
Ask Edcor to make you a power transformer, possibly they already have one in their catalog to suit, and if that is the case you will not have to pay the $40 NRE cost for a custom design.. They're quite obliging, and this is what I do for most of my designs.
"To argue with a person who has renounced the use of reason is like administering medicine to the dead." - Thomas Paine
Old 8th August 2012, 04:49 PM   #3
Osvaldo de Banfield is offline Osvaldo de Banfield  Argentina
Osvaldo de Banfield's Avatar
Location: Barrio Garay,Almirante Brown, Buenos Aires, Argentina
An alternative solution is to use a higher voltage transformer's secondary, and go to choke input filter. This last, also extend the rectifier´s life.
Osvaldo F. Zappacosta. Electronic Engineer UTN FRA from 2001.
Argentine Ham Radio LW1DSE since 1987.
Old 8th August 2012, 05:15 PM   #4
Thanks Kevin. I will see what Edcor can come up with. Taking the tube compliment of this amp into account what do you think my target B+ should be after rectification and filtering? 6005s have a Max plate voltage of 250 so I was going for about 210-220V. Sound right??
Old 8th August 2012, 07:38 PM   #5
TheGimp is offline TheGimp  United States
TheGimp's Avatar
GE Data sheet gives a recommended operating point at 250V plate and G2, -15V G1, 70mA for a pair of tubes AB1 PP.
If the kit runs cathode bias, you can subtract the magnitude of the G1 voltage from the plate voltage.
You also drop a few volts across the OPT, so a B+ of 265-275 is reasonable.
Old 9th August 2012, 03:11 PM   #6
hollowstatefan is offline hollowstatefan  United States
You've probably taken into account, but you'll need to supply heater current for the 6BY5GAs, too, each 1.5A @ 6.3 V.
Power Transformer HelpHide this!Advertise here!
Newbie Question - Power Transformer vs Isolation Transformer SparkyPete Tubes / Valves 10 2nd November 2012 06:13 PM
High Power Transformer/Power supply PCB for Sale. Count Tubeula Parts 2 26th October 2012 07:45 AM
power transformer as output transformer seedseed Analogue Source 18 7th May 2011 06:52 PM
toroid Transformer as power Transformer for tube tone Tubes / Valves 7 11th February 2003 08:57 AM
Good price on huge power transformer for power amp. G Solid State 3 15th September 2002 01:23 PM
