Dynaco low Power Amp - Page 5 - diyAudio
Old 9th September 2012, 01:27 PM   #41
mr2racer's Avatar
Hey, if anyone is still listening. Do I want to match the input voltage of the anode follower at the grid to match the output voltage from the plate? Is it that simple?
Old 9th September 2012, 01:58 PM   #42
DF96 is offline DF96  England
You want the output voltage at the anode of the anode follower to match the voltage at the anode of the first stage. The grid signal will be smaller by about mu. With equal resistors the fractional error in the outputs will be about 2/mu.
Old 9th September 2012, 04:44 PM   #43
mr2racer's Avatar
DF96,
Is that why I have IM at higher power levels? So it IS an AC balance issue?
Old 9th September 2012, 05:01 PM   #44
If you have phase splitter imbalance then you would get incomplete cancellation of even order distortion (harmonics and IM) in the output stage. This would show up more at higher power levels. It would not affect odd order distortion.
Old 9th September 2012, 06:06 PM   #45
mr2racer's Avatar
Thanks very much DF96. I'll make the changes tonight.
Can I use MANY MANY low power devices for 1 HIGH power amp? SkinnyBoy Solid State 35 8th July 2013 10:44 PM
Dynaco Low Power with 12AY7's mr2racer Tubes / Valves 1 25th July 2012 07:59 PM
preamp supply LOW power LOW noise LOW cost drdagor Power Supplies 1 13th September 2010 11:39 PM
Van Alstine Mosfet 150 Modified Dynaco ST 150 Power Amp Scott Novak Swap Meet 1 7th August 2009 10:45 PM
Need work done on a dynaco power amp ag2217 Tubes / Valves 1 6th August 2007 11:35 PM
Copyright 1999-2017 diyAudio
