Dynaco low Power Amp
Old 3rd September 2012, 03:09 PM   #31
stajo is offline stajo  Sweden
Good to hear, congrats and thanks for the info!
Im also into tweaking the feedback but I'm a bitt puzzled about doing it on the 1k resistor since it also changes the working points of the splitter. My recent plan is to try to locate best value the feedback bypass cap with a scope and also set the splitters balance with the 47 k resistor first.
I might try with pot on the 1 k if that doesnt help. Thanks!
Staffan
Old 3rd September 2012, 05:05 PM   #32
mr2racer is offline mr2racer  United States
mr2racer's Avatar
Stajo,
I departed from the schematic and separated the feedback loop from the cathode resistor. I used the 1k resistor to ground the cathode to the star ground NOT through the output transformer. Then used the feedback loop on its own. The design was nice in that it could use a single loop for the cathode and feedback. But I suspect it only works with those transformers.
Old 3rd September 2012, 05:54 PM   #33
20to20 is offline 20to20  United States
Originally Posted by mr2racer View Post
Stajo,
Racer,
If you have a 560R feedback from OPT to cathode you have just paralleled with the 1K and now have @ 400R (without my calc.) as cathode resistance instead of the original 1K.
Old 4th September 2012, 05:17 AM   #34
I separated the preamp tube cathode resistors and stuck with the 1k but didn't ground them threw the output secondary.
racer; where do you insert the feedback? Can you do a little scetsh of the input cathode couplings?
Best regards
Staffan
Old 4th September 2012, 06:11 AM   #35
revintage is offline revintage
Hey,
You seem a little lost here!
This way you can adjust NFB anyway you want it, without messing up the working points.
Use Rfb to adjust.
Working points are per the original circuit.
Also note, assymetry from the original driver signal must be adjusted. Make R19 220k and use a 100k trimmer for R21.
Old 5th September 2012, 05:19 AM   #36
If you donīt want a trimmer, substituting R19 with 240k will give you a theoretical assymetry in the ballpark of 0,3dB. If you keep the original 270k, assymetry will 1,5dB. But no worry, it is mainly 2H that is affected.
Old 7th September 2012, 02:17 AM   #37
mr2racer's Avatar
Revintage,
Why are your R19 and R20 different? The original schematic shows both at 270k?
Old 7th September 2012, 05:15 AM   #38
To get rid of driver assymetry! See post #35 and #36. Gain of anode follower U5 must be adjusted for exactly 0dB gain. Not possible with 270k.
Old 8th September 2012, 01:36 AM   #39
mr2racer's Avatar
OK Revintage,
I understand the change to the schematic. But how do I measure the adjustment? Is this like an AC balance adjustment?
Old 8th September 2012, 02:10 AM   #40
mr2racer's Avatar
OK Revintage,
I understand the change to the schematic. But how do I measure the adjustment? Is this like an AC balance adjustment? Do you want the AC voltage at the plates of U4 and U5 to match?
Dynaco low Power AmpHide this!Advertise here!
Can I use MANY MANY low power devices for 1 HIGH power amp? SkinnyBoy Solid State 35 8th July 2013 10:44 PM
Dynaco Low Power with 12AY7's mr2racer Tubes / Valves 1 25th July 2012 07:59 PM
preamp supply LOW power LOW noise LOW cost drdagor Power Supplies 1 13th September 2010 11:39 PM
Van Alstine Mosfet 150 Modified Dynaco ST 150 Power Amp Scott Novak Swap Meet 1 7th August 2009 10:45 PM
Need work done on a dynaco power amp ag2217 Tubes / Valves 1 6th August 2007 11:35 PM
