300b - diyAudio
Old 4th August 2012, 02:10 PM   #1
Default 300b
I want to adjust the flow of two different brands 300B
The strength that I have is 880 ohm adjustable and if I could adjust
You have to drop the resistance I insert the milliammeter of resistance
ground to fine adjust?
Another issue is that capacitors are good for power, I have
a 47uf-600v solen of the input and filter after the shock of two
Mundorf of 47 +47 and the other is the step that I have I have two Dynamicap.
a greeting.The valves 300B gold Lion and Electro-Harmonix
Old 4th August 2012, 04:16 PM   #2
Palustris's Avatar
Rather than insert an ammeter between the cathode resistor and ground you can insert a 10 ohm resistor. Then measure the voltage drop across the resistor and use ohms law to determine the current. This way you can measure the current whenever you want without having to unsolder a connection.
Old 4th August 2012, 05:23 PM   #3
Vinylsavor's Avatar
Hi!
If I understand correctly you are using auto bias with a cathode resistor of 880 Ohm.
Why make it adjustable? The point of this bias scheme is that it's automatic and the tube finds its operating point all by itself.
Thomas
http://vinylsavor.blogspot.com/
Old 4th August 2012, 05:24 PM   #4
kevinkr's Avatar
"To argue with a person who has renounced the use of reason is like administering medicine to the dead." - Thomas Paine
Old 5th August 2012, 11:23 AM   #5
Default 300B
for fine adjustment Adjustable think is ideal for when you switch
valve mark differences. On the other hand it could put a jack
to see the current. an issue that was impossible to leave for the delay
buy a sophia electric, when it enters the high tensiion shakes my cone
Speaker TannoyMonitor gold could anyone know where to put.
thanks
Old 5th August 2012, 12:44 PM   #6
Vinylsavor's Avatar
Hi!
The cathode bias method allows the tube to settle where it 'feels most comfortable'.
The proper way to make current adjustable is with fixed bias. The name is mis lieading. fixed bias means to supply an adjustable bias voltage to the grid and ground the cathode.
Bets regards
Thomas
FS: for 300B (JE Labs 300B SE) builders cartman Swap Meet 2 29th October 2008 01:13 PM
Which 300B ? JC951t Tubes / Valves 33 1st August 2008 02:25 PM
* 35 watt * 300B SE = super 300B + Class A2 rick57 Tubes / Valves 4 13th July 2005 04:18 PM
300b? Alastair E Tubes / Valves 26 1st March 2004 11:37 PM
Well, tell me what you think ( 300b ) Magnetmaz Tubes / Valves 52 11th June 2003 08:07 PM
Copyright 1999-2017 diyAudio
