SANSUI AU-70 or 1000A???
Old 3rd August 2012, 02:14 AM   #11
aandre2200 is offline aandre2200  United States
Thanks, Michael. You make a very good point. I ran the tests off a variable transformer at 60Hz, no load, no scope. I will redo the testing as you recommended. I need to find a generator that can supply a voltage high enough to get one volt on the secondary taps.
Now I have some work cut out for me!!!
Thanks again.
Old 19th August 2012, 05:44 AM   #12
analogadikt is offline analogadikt  India
This thread is of interest to me as I have a 1000a that needs to be overhauled before it is put in service. I found the service manual on AK, the parts list section of the manual specs the OPTs as 6 kOhm primary and 8,16 Ohms secondary. No part# is mentioned.
analogadikt
SANSUI AU-70 or 1000A???Hide this!Advertise here!
Sansui AU-3900 mot on/off Solid State 19 10th February 2015 07:47 AM
sansui 1000a maintenance dognut Tubes / Valves 1 18th February 2009 12:51 AM
Sansui 1000A output transformers JohnG Swap Meet 7 27th February 2006 10:39 PM
Sansui 1000A OPT's jlsem Tubes / Valves 1 7th July 2005 05:10 PM
Sansui Au-517&au-717 ManUtd Solid State 4 29th March 2004 01:13 AM
