humbucking filter choke - how different? - diyAudio
Old 19th October 2003, 03:21 PM   #1
zobsky is offline zobsky  India
zobsky's Avatar
Default humbucking filter choke - how different?
What is and how is a humbucking filter choke different from a normal power supply filter choke?
Can it be used as a PS filter choke, and are there any disadvantages/advantages? Its specs are:
16 Hy/175ma/96 ohms. Parallel 4 Hy/350ma/24 ohms
thanks, vin
Old 19th October 2003, 05:30 PM   #2
zobsky's Avatar
never mind, a web search turns up that a hum bucking choke taps a bit of the voltage and feeds it out of phase to the output sde, hence cancelling PS ripple.
if this is correct, i wouldn't want to use this for a hifi circuit
Old 19th October 2003, 06:21 PM   #3
diyAudio Senior Member
fdegrove's Avatar
Why not?
Frank
Old 19th October 2003, 07:20 PM   #4
zobsky's Avatar
wouldn't tapping ripple and purposefully introducing it later in the circuit act like a sort of "feedforward loop". nothing inherently wrong in that, but as a beginner, i'd like to keep it simple.
that auction just ended, ..but if you think it might not be a bad idea, please explain and i will keep my eyes open next time.
BTW, .. this is for the 6sn7 pre-amp you helped me get working sometime ago. works well, .. and i have built in a 6bq5 SE amp too, but the thing hums, ..
what kind of current capability should i look for in a choke for this arrangement
thanks
Old 19th October 2003, 10:23 PM   #5
fdegrove's Avatar
Nothing's ever perfect, but that's how it works.
I remember that. Hum is usually always induced by bad lay out...maybe we can solve that too?
What's the current going through the circuit?
Frank
Choke Input Filter. G Tubes / Valves 8 11th February 2008 09:57 PM
Ps Filter Cap or Choke? Dr.Frankenstein Power Supplies 3 11th March 2006 08:51 AM
Filter Choke BC Parts 2 22nd September 2004 10:36 PM
SOZ Choke input filter? gnomus Pass Labs 48 14th May 2004 07:41 PM
Choke for Pi Filter lumanauw Solid State 48 5th February 2004 10:44 PM
Copyright 1999-2017 diyAudio
