NOS potted Chicago Transformer 1BC-150 - diyAudio
Old 26th July 2012, 07:33 PM   #1
yero is offline yero  United States
Default NOS potted Chicago Transformer 1BC-150
Can anyone provide a link that explains how I can combine the secondary voltages to produce the maxium output voltage. The secondaries are 125V,100v,75v and 50v. It says 150ma which I believe implies 150ma for each secondary. The box also says output volts from condenser input filter using 5u4 tube. the secondary also has 5v at 3A. for the rectifer tube. Is it possible to connect together the secondaries to produce 300-350volts. If not connected in phase, will the voltages subtract? How is phase determined, trial and error?
Old 26th July 2012, 07:44 PM   #2
Sorry,The potted Chicago transformer model # is 1BS-150 with 13 bottom lugs
Old 26th July 2012, 11:53 PM   #3
7N7 is offline 7N7  United Kingdom
7N7's Avatar
Of course I have no idea of the size of the transformer, but I should think that the rating of 150mA applies to the secondary in total.
The best way to determine phase is to use an oscilloscope. Failing that (and what I have done recently) is to connect the secondaries and connect the output to a fast-acting meter. If the voltage drops then it's out of phase; left powered the transformer will get very hot indeed. Normally with such transformers there are taps for the various voltages and a single 0v terminal.
7N7
Plug them in and light them up
Old 27th July 2012, 03:07 AM   #4
Thanks 7n7. Can't exactly follow your explanation. the transformer's dimensions are 4 in. H. X 3 1/4 W. X 3 in. wide and weighs 5 pounds. I have located the catalog but can not find the pin out. What is the 0v terminal for? Does the size and weight help determine what the current rating is for the transformer at 350volts. I do not have an oscilloscope yet. I would like to use this transformer for a push pull EL84 AMP. Any help from anyone is greatly appreciated. Yero
Old 27th July 2012, 06:33 AM   #5
When 7n7 talks about connecting the secondaries and connect the output to a fast acting meter, do I connect the secondaries in series or parallel to obtain max. voltage at 150ma. does fast meter imply some thing like a fluke 87, I only have a 77- but can't an analog meter work good for this application. I can imidately recieve an indication of up or down in voltage using stand alone voltage meter with manual range voltage adjustment taps Analog meters, which I have access to. Is this what is ment by fast-acting meter? all assistance is appreciated. Yero
Old 27th July 2012, 08:51 AM   #6
AJT is offline AJT  Philippines
AJT's Avatar
first you have to find out if the secondaries are separate windings or just a continuous winding with several taps...you need a dmm set to ohms to do this...the terminal marked 0 is usually the starting point to measure all other voltages...
Do not despair, though they seem to be winning
now, they always fall in the end......Gandhi
Old 27th July 2012, 10:37 AM   #7
7N7's Avatar
Your meter will be fine and as Tony says it's a good idea to establish whether or not the secondaries are one continuous winding or separate ones, If this is the case of course you will have a 0v terminal and one each for 50v, 75v 100v and 125v. If the windings are separate, then there will be two terminals for each voltage.
7M7
Old 27th July 2012, 10:47 AM   #8
AJT's Avatar
a picture showing nameplate data or pin arrangements will definitely help....
Old 27th July 2012, 07:22 PM   #9
looks like you have a bias trasformer with contunious windings .
http://www.bunkerofdoom.com/xfm/chicago1953/005.jpg
To be better one must be different ,but to be different is not necessarily better .
Old 27th July 2012, 08:04 PM   #10
picture of transformer
Partidge output transformer, potted, fantastic bentoronto Swap Meet 3 2nd June 2010 12:43 PM
Heathkit potted power transformer question Boris_The_Blade Tubes / Valves 4 19th September 2007 04:29 AM
Potted Transformer Enclosure Suppliers? Yukonsc Parts 3 1st December 2006 03:44 PM
custom transformer manufacturers (potted if possible) jarthel Tubes / Valves 11 5th June 2006 07:51 PM
suitability of this potted transformer for chipamp? jimbo1968 Parts 1 11th June 2005 04:27 PM
Copyright 1999-2017 diyAudio
