Post-mortem on a 80 year old 2A3 amp
Old 25th July 2012, 11:11 PM   #1
cuibono is offline cuibono  United States
cuibono's Avatar
Default Post-mortem on a 80 year old 2A3 amp
The amp in question comes from a late-30's RCA-designed, Story and Clark electric piano, the Storytone. It is a 15W output beast, single channel, with four 2A3 tubes in push/pull parallel. It has two power transformers, and three signal transformers. At idle it consumes about 200W! The piano itself is beautiful, very 30's art deco, and was possibly the first electric piano.
I was able to find a schematic luckily. The power supply was fried at some point - I attached a picture of the melted transformer next to a 2A3 tube for size comparison. Its a pretty big transformer, and was used to generate the plate voltages. I'm hoping to be able to replace it, figure out what went wrong, and get the instrument working again.
Heres the evidence so far:
1) a 30 amp fuse, where a 3 amp is called for - duh!!
2) plate power transformer melted and still gooey
3) 5Z3 rectifier tube internally melted
4) no other components melted. One of the 2A3 tubes has very low output (tested at 40% quality on a hickok tester), but doesn't look to me like the reason the amp fried
The schematic shows that the plate transformer, T4, is supposed to have 120V in and 340Vac out. Its also says the primary is 2.9ohms and the secondary is 70ohm total. I actually have a second power supply with a good transformer, so I can do measurements on it if need be.
So my questions are, could the 5Z3 tube short internally, melting the transformer? And where/how can I replace the transformer? I'll have one custom made if need be.
Old 25th July 2012, 11:17 PM   #2
vaughn is offline vaughn  United States
I have no answer to your question, just want to comment on what a beautiful object that piano is
Old 25th July 2012, 11:28 PM   #3
trobbins is offline trobbins  Australia
trobbins's Avatar
Are you sure the plate PT is bad? Have you checked it electrically?
I'd be certainly interested in also seeing a schem of the remainder of the piano - eg. the tone generation/sgnal processing.
Can you provide a photo of the underside circuitry?
Top stuff!
Ciao, Tim
Old 25th July 2012, 11:45 PM   #4
HollowState is offline HollowState  United States
HollowState's Avatar
Technically possible, but unlikely. More likely is a short somewhere else after the 5Z3. But for sure that 30 amp fuse caused the meltdown when it didn't blow. I've seen this too many times in various equipment where some moron puts a "slug" in place of a fuse.
As far as transformer replacement goes, you'll have to search the various transformer manufactures listings for one that's close. I'd start with Edcor, Hammond, etc. And also search eBay for a good used or NOS Stancor, Thordarson, Triad and others. Having one made special would be my last resort because of cost.
1944: 18 year olds storm the beach of Normandy into almost certain death.
2017: 18 year olds need a safe place because words hurt their feelings.
Old 26th July 2012, 12:32 AM   #5
kevinkr's Avatar
Edcor can probably build something suitable for not obscene money, however it probably will not be physically identical.. There are transformer rewinders that could do a complete rewind on this transformer for what is probably a substantial cost - given the nature of the beast it might just be worth it.
Most likely one or more of the supply filter caps croaked. I have an Atwater Kent Radio from 1932, mostly original parts except for the electrolytics which I stuffed with modern caps. The originals were wet types and had totally dried out. (and shorted)
"To argue with a person who has renounced the use of reason is like administering medicine to the dead." - Thomas Paine
Old 26th July 2012, 12:49 AM   #6
trobbins's Avatar
The wax or pitch of old transformers would often melt out over time. For sure, excess expulsion indicates gross heating, but may not end in winding failure. A resistance test, followed by a low AC voltage excitation test, followed by a megger/insulation resistance test would be the first actions I suggest.
Old 26th July 2012, 05:16 PM   #7
Tom Bavis is offline Tom Bavis
Tom Bavis's Avatar
As a compromise, if you can find a similar transformer of the same core size, the end bells can be swapped to keep it looking original. I would be amazed if the winding WASN'T shorted or open, and wouldn't trust it if it did measure OK... as mentioned above, shorted cap would cause rectifier and transformer to fail.
Old 26th July 2012, 05:37 PM   #8
Osvaldo de Banfield is offline Osvaldo de Banfield  Argentina
Osvaldo de Banfield's Avatar
Location: Barrio Garay,Almirante Brown, Buenos Aires, Argentina
Check the electrolytic cap's. I have some problem with old sets including tube rectifiers, in which electrolytic become shorted or very leaky. As the cap drains more current that rectifier can supply, it becomes red plated, and then gas is liberated inside the bulb. Then, more current, and so. The final is the filament melted, and touching the plate were arcing or directly shorted to an anode. In an old Paco oscilloscope S50, (from 70's ?) it happened with a 6CA3, when the final was the cathode shorted to heater. And more recently, with a restored Eico 368 signal generator of my own. Then, I rewind the transformer for 220V (The original was 110V primary), and made a separate heater wind to the 6X4 to prevent cathode-heater insulation damage. This set works with 380V cathode voltage, when RCA specifies about 200V absolute maximum between cathode-heater voltage.
Osvaldo F. Zappacosta. Electronic Engineer UTN FRA from 2001.
Argentine Ham Radio LW1DSE since 1987.
Old 26th July 2012, 06:41 PM   #9
Wavebourn is offline Wavebourn  United States
Designer & Technologist
Wavebourn's Avatar
In any case electrolytics caps have to be replaced.
And I second Edcor as the source for transformer.
You live quite far from SF Bay Area, and I have more project than can afford, otherwise I would offer my help in restoration of this beauty.
The Devil is not so terrible as his math model is!
Old 26th July 2012, 10:45 PM   #10
7N7 is offline 7N7  United Kingdom
7N7's Avatar
It is absolutely stunning; I adore Art Deco and this instrument is a fine example indeed.
7N7
Plug them in and light them up
Post-mortem on a 80 year old 2A3 ampHide this!Advertise here!
Post mortem of an ESI nEar 05 studio monitor with pictures stube40 Solid State 24 24th December 2012 03:55 PM
SSE Post-mortem help spopepro Tubelab 3 20th April 2011 01:29 AM
Marantz SC-80 / SM-80 repair queries Low Orbit Solid State 2 26th May 2010 06:36 PM
Aleph 30 post-mortem spzzzzkt Pass Labs 56 17th February 2008 07:29 PM
Krell KSA 80 bias & dc offset check & adjust procedure Clouseaupte Solid State 3 9th August 2007 09:39 AM
Copyright ©1999-2017 diyAudio
