Old 25th July 2012, 09:54 PM   #1
Default 6e5p gm70 with 6d22s?
Hi all
sorry if this is a stupid question, but i've always been of the understanding that capacitor value after a valve rectifier was limited, ie 40~60uf
Having just read a load of posts conserning 6d22s's it seems i could use much larger values after a choke in a pi filter, is this correct? Duncan ps simulator doesn't flash up any warnings which seems promising what are peoples experiences with the damper tubes and bass speed ?
The amplifier as it stands has 6e5p mu follower running from 700v @ 200v 23ma the load resisters drop 300v and so produce quite some heat.
ps is 400 0 400 bridge rectifier using series 4007 to a 10H 350ma choke then 4 x 1500uf 250v in series producing 725v.
GM70 are biased with 470r for -50v ish at 675v
i'm planning on fitting a small value pio cap before the choke to give me ~900v and use fixed bias on the GM70s. as 6d22s@s are quite cheap and seem to have some favorable reviews sonicly i was considering them, but was put off by having to have small value capacitors which from my modest experience fiddling with old quad 11's gives bloated bass.
ultimatly i hope to have a great sounding amp, roughly 10-20watts and keeping it domesticly acceptable ( not cool i know!) so that means keeping it in or on its 300 x 110 x 600mm chassis and that demands limiting hot components within the chassis which aint easy with gm70's i'm finding out!
enzo
6e5p WCF headphone amp with no cap! mogliaa Tubes / Valves 59 1st June 2012 02:05 PM
6E5P Jaime Tubes / Valves 6 10th March 2011 07:17 PM
C3g:GM70:GM70 schematic advice louischia Tubes / Valves 24 27th August 2010 04:01 PM
6e5p Vladi59 Swap Meet 0 18th March 2009 07:26 PM
GM70/GM70 parafeed SET? louischia Tubes / Valves 10 4th December 2008 03:12 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
