Old 24th July 2012, 06:36 PM   #1
Default monarch 614
I've got a Monarch 614 se. Any suggestions for upgrades?
Old 24th July 2012, 06:41 PM   #2
Osvaldo de Banfield's Avatar
Location: Barrio Garay,Almirante Brown, Buenos Aires, Argentina
The only suggestion I can do is o use a UL output, and too replace the first resistor in PS by an inductor.
LW1DSE
Old 24th July 2012, 06:43 PM   #3
frugal-phile(tm)
planet10's Avatar
All the caps likely need replacing,
I'd add a power supply choke and convert it to an RH84.
If anything like the ECL82 versions i have, it will have very nice iron.
Pictures?
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 24th July 2012, 06:43 PM   #4
TheGimp is offline TheGimp  United States
TheGimp's Avatar
Increase the value of the (25uF) cathode bypass cap.
Old 24th July 2012, 08:48 PM   #5
Default monarch 614
Found this amp a few years ago in an antique store. Hardly any use.
Trying larger coupling caps(.22), not sure if they make any difference.
Monarch STA-100X Refurb wrenchone Tubes / Valves 7 19th September 2009 06:33 PM
Monarch 4" driver woody Swap Meet 1 15th March 2005 11:28 PM
philips cd604/614 schematics Peng Digital Source 6 28th February 2004 07:53 AM
Copyright ©1999-2013 diyAudio
